Author Topic: Car pitching when turning right  (Read 1841 times)
AJH1973
« on: 30 September 2008, 22:10 »
Hi all,
Had a look through the various posts on here and can't see this covered anywhere!
I've got a 8v GTI which seems to pitch down on the front passenger side when I turn right more than the driver  side pitches down when I turn left - hope that makes sense! It drives OK but can be a bit unerving if you forget about it and go in to a right hand bend a bit quick!!
Just wondering if anyone can confirm if this sounds like an issue with the ARB bushes or more likely to be the shocks/springs?
Alex
Offline Jay
  • balding fat cvnt
Re: Car pitching when turning right
« Reply #1 on: 30 September 2008, 22:46 »
I would have said a shocker, but not sure about the ARB bushes and what happens if they go.
I'm sure someone will enlighten us momentarily :smiley:
What happens when you press down on that corner? Does it keep bouncing or does it stop bouncing fairly quickly?
AJH1973
« Reply #2 on: 30 September 2008, 22:49 »
It acts the same on both front corners i.e. doesn't bounce at all. The shocks are fairly new which is why I am suspecting the ARB. I'm just after a bit of guidance before I start buying bushes and taking things apart!!!
Offline danny_p
« Reply #3 on: 01 October 2008, 18:54 »
bushes clunck when they are worn,    would suggest haveing a very close look at the springs if your sure its not the dampers.
it's supriseingly common to find mismatched springs on cars   espectaly if someone has fixed a dead shocker  by swaping a strut from a diffrent car
all the VW's have gone bar 1.
AJH1973
« Reply #4 on: 01 October 2008, 20:44 »
Thanks for the replies sounds like it may be the springs!! I went out and checked it again earlier and whilst it doesn't bounce on either side it is definitely easier to push down on the passenger side than the drivers side. No doubt a dumb question but could it be the shocks have been set up wrong- the car has adjustable Koni's on it- i.e. one side set harder than the other??
Next dumb question is it a major job to check the springs or can a novice do it with a few tools?
Thanks again for all the advice!
Offline Organisys
  • Old and Slow...
« Reply #5 on: 01 October 2008, 21:19 »
Wind both shocks all the way to soft (should be anti-clockwise) and test again.
AJH1973
« Reply #6 on: 01 October 2008, 21:22 »
Can you do this while they are on the car or do I have to take the spring and shocks off??
Offline danny_p
« Reply #7 on: 01 October 2008, 22:40 »
ahh if have adjustable shocks thats more than likely to be it.     adjustable frount shocks can normaly be adjusted "on car"  IIRC  konis are top adjustable  so remove your strut top caps so you can see the nut that reatins the shock and in the center there will be a small shaft  your soposed to adjust them with the knob that comes with the shocks  but if this is missing or the shock a bit mangeld you'll have to improvise
Offline Goops
  • mk2 gti 16v
« Reply #8 on: 01 October 2008, 22:55 »
Switched to konis with adjustable damping a few months ago, like above, remove the strut caps and you will see a male wedge that you can twist both ways...think its clockwise to soften and vice versa!
Offline Organisys
  • Old and Slow...
« Reply #9 on: 02 October 2008, 12:34 »
Yes. You should be able to adjust them on the car.
