Author Topic: Injector Seals ?  (Read 866 times)
Offline sdall30
Injector Seals ?
« on: 29 September 2008, 13:31 »
I'm in the process of rebuilding the head on my valver and have been told by a friend that it's best to replace the injector seals befor re fitting the injectors , I rand the local stealership and told them year engine size ect , and told them it was a PB engine and they kept going on about a seal kit and that it wasn't an off the shelf part.. Are they telling porkies or what ??
Where's the best place to get them from and what should I be asking for ?
Offline Mr Blue
Re: Injector Seals ?
« Reply #1 on: 29 September 2008, 14:07 »
do you mean the little O rings on the injectors? - My head gasket set came with these.
or the seats that sit in the cylinder head? - These can be reused if in good condition. They unscrew with a large allen key/socket
Offline sdall30
« Reply #2 on: 29 September 2008, 14:22 »
It's the seats that sit in the head , they don't look too bad but seeing as it's off and accessable I thought I'd change them anyway
Offline Mr Blue
« Reply #3 on: 29 September 2008, 14:42 »
i didnt bother with mine. they cleaned up well and hardly any ware. Worked fine but its up to you. Someone on here may have a part number for you :smiley:
Offline Mew
« Reply #4 on: 29 September 2008, 16:21 »
16v engine won't be a PB code
Offline Conker
« Reply #5 on: 29 September 2008, 21:21 »
If its a 16v, I got new injector seals from GSF - they cost literally pence.
