Author Topic: 17" wheels on ED30?  (Read 12872 times)
Offline RedRobin
Re: 17" wheels on ED30?
« Reply #20 on: 29 September 2008, 12:51 »
DSG has different diameter mounts to Manual. So I'm told. :undecided:
....Yup, I believe so - 50 and 55 mm.
:afro:
Offline Teutonic_Tamer
« Reply #21 on: 29 September 2008, 13:35 »
As RR says .. don't expect a big difference in the ride.  I have also driven a a GTi  with both 17"'s and 18"s,   and agree with RR comments.  The tyre brand nearly made as big a difference as the size of wheel (to the ride).  What tyres are you currently on ?
Agreed, to an extent.  But actually, the tyre can have a major factor in ride comfort.  ContiSportContact2 and Dunlops have a very harsh ride, whereas Michelins are renown for their much softer ride comfort.
I feel like a homo
« Reply #22 on: 29 September 2008, 13:39 »
Are the Eibach coilovers adjustable?
Fixed damping, but adjustable height and spring rate.
Huh - than can't be so.  The spring rate is determined during manufacture, and altering the adjusters merely alters the preload on the spring, and therefore the ride height.  However, if the spring has variabl pitch coils, then the "apparent" rate may rise as the spring compresses.  Sounds like someone has been telling you porkies!  :rolleyes:
I feel like a homo
« Reply #23 on: 29 September 2008, 13:44 »
But why would the springs be different for a DSG car? - If it's weight related, then there's a difference between the 3-door and 5-door versions.
They shouldn't.  The difference between the manual gearbox and the DSG box is minimal - sommat like 30kgs.  However, the difference in weight between a petrol engine and a diesel engine is quite substantial - often around 80-100kgs for a 4pot.
Therefore, if it says TDI on the box, it won't be suitable for the GTI, DSG or no DSG!  :huh:
I feel like a homo
« Reply #24 on: 29 September 2008, 13:47 »
well, at a guess and i'm no expert they either put a different spring on the DSG because the weight is aimed more towards the front of the car hence needing a different spring to allow for this so the car can sit right as well as handle correctly, or they have a slightly different strut on DSG cars (although i doubt it)
Nope.  DSG and manual springs are/should be identical (based on the plated load of the front axle) - and the struts will be physically identical too.
« Last Edit: 29 September 2008, 13:49 by Teutonic_Tamer »
I feel like a homo
« Reply #25 on: 29 September 2008, 13:52 »
Nope.  The physical dimensions of the struts are identical.  It is the driveshafts which are different, and these are not part of the suspension!
I feel like a homo
Offline 182_blue
« Reply #26 on: 29 September 2008, 13:54 »
well TT you need to tell Eibach that
Offline joesgti
« Reply #27 on: 29 September 2008, 14:02 »
....Robin
whats with the .... everytime you post, lol  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
« Reply #28 on: 29 September 2008, 14:05 »
So, why do Eibach have different part numbers for the TDI and the GTI?  :smug:
Any automotive engineer will tell you that the plated limit, ie, the Type Approval axle weight limits are one of the primary reasons which determine the spring rate.  And the Golf TDI has a considerably higher front axle loading than a GTI.  :nerd:
I feel like a homo
Offline 182_blue
« Reply #29 on: 29 September 2008, 14:09 »
i have no idea, it was me who said that he had the wrong springs to start with, its Eibach thats told RR that the tdi ones are fine
