Author Topic: 8v starting/running problem  (Read 991 times)
Offline jambon
« on: 27 September 2008, 18:15 »
Hopefully someone can shed some light on this for me because it's getting depressing walking past ma wee golf.
I'v recently bought a '91mk2 8v,Which has been great up till last week,
Driving home from work last week it was running rough and chucked it 100yards down the road,
Towed it home and started checking,No spark from the coil so decided it need's a new one,went in orderd one and packed my case to go on holiday.
Came home yesterday and fitted the new coil still no joy  ,started checking everything again,While i was i had left the ignition on and after about 1min i could hear what sound's like something shorting out around the top/rear of the engine,while it's doing this i can hear the coil sending a spark down to the dizzy cap,and the rev counter is erratic.While this is happening if i turn the key the car will start  Runs rough but run's,I'm guessing at a bad earth somewhere? I'v cleaned the earth running from the coil to the rocker and the one from the neg on the battery but still no joy.
Missus is starting to give me grief now to get it sorted because im using her car at the mo and she's no a happy bunny!
Offline byebye
Re: 8v starting/running problem
« Reply #1 on: 27 September 2008, 18:24 »
could be the halls sender....on the side of your dizzy cap theres a block conector give it a clean. i had a similar problem..mine was that the king lead to the coil was not pushed home properly..they are little tw@ts to get on cos its buried away. :wink:
if you had been under the bonnet cleaning or fiddling previous to the problems you might have pulled something off.
btw it never hurts to clean up the main earths
Offline jambon
« Reply #2 on: 27 September 2008, 18:29 »
Cheer's buddy,
I meant to add i tried a different king lead and it made no difference,I'll give the hall sensor a clean in the morning,Also i replaced the rotor arm which had a scorch mark(almost burned to a hole)just off center,If i can i'll get a pic of it i'll post it up.
Offline byebye
« Reply #3 on: 27 September 2008, 22:04 »
no worries  :wink: a pic would be  :cool: also you did put the lead back on the right way  :huh: and re-check all the leads on the coil they break easy and can short out  :rolleyes:
Offline mattkh
« Reply #4 on: 27 September 2008, 22:12 »
Hi
In that case what state was the carbon brush inside the dizzy ??
Offline jambon
« Reply #5 on: 28 September 2008, 14:59 »
The inside of the cap is still like new,
It's lead me a merry dance but i'v got it going now :grin:I havn't a clue what sorted it,just cleaned up various connecters and farted about with the dizzy cap.
Just been out for a wee blast and it's as good as new :smug:
Thank's for the help guy's
Offline byebye
« Reply #6 on: 28 September 2008, 16:59 »
 :wink: glad its ok sounds like a dirty conector that has now been cleaned  :wink:
