Author Topic: Bl**dy great hole!  (Read 1144 times)
VW BUSH
Bl**dy great hole!
« on: 27 September 2008, 18:02 »
Whilst Climbing around underneath sorting Exhaust mounts and undersealing, i found this.
Offline Dragon6
Re: Bl**dy great hole!
« Reply #1 on: 27 September 2008, 18:32 »
Is that around those dreaded plastic grommet/blanking holes they can hold a multitude of nastiness if you start proding around those things...
sharpie
« Reply #2 on: 27 September 2008, 19:03 »
get it welded
VW BUSH
« Reply #3 on: 27 September 2008, 23:29 »
Sorted it with weld, plate fibre glass and loads of underseal!
Pulled all the other grommets out and waxoiled and undersealed them, Found another right by this one but on the sill, can feel a hole behind the VW underseal, think ill do it in a couple of weeks and weld in the jacking points with some more plate at the same time!
Also found cracked underseal by rear axle bracket so that prompted me into  major undersealing every where and wax oil to boot.
black fingernails :laugh:
