Author Topic: Clutch cable  (Read 1006 times)
Offline hockeylad72
Clutch cable
« on: 27 September 2008, 17:51 »
Just had new clutch fitted and when in 5th gear clutch starts to slip. It has one off these self adjusting clutch cables on it how do you over ride it to re adjust for having a new clutch?
Will be looking to get manually adjustable cable - where do i get these from?
Mk3 golf 1.9TD AAZ eng code 1997
Any help/ assistance would be appreciated
cheers
Davie
Offline boneybradley
  • Back in a Mk3...
Re: Clutch cable
« Reply #1 on: 27 September 2008, 18:53 »
if its had a new clutch the cable should get done at the same time as the adjuster only works 1 way....time for a new one (£35-45 for the self adjuster or if you earch you can get a manual one for £20-25)
Offline hockeylad72
Re: Clutch cable
« Reply #2 on: 27 September 2008, 19:08 »
Thanks for that.
Is there a how to anywhere - tried a search but found nothing
