Author Topic: 8v and 16v Cats and exhausts.....  (Read 1729 times)
Offline Mikester
  • Civic Type R
« on: 27 September 2008, 12:08 »
I have an 8v as most of you probably know, you probably also know i have a custom powerflow straight through and sports cat. You probably also know my mk3 has a wing differently coloured due to an A-hole hitting my car.
I cba to get it all sprayed and fixed in the end. So i have decided to EITHER get another 3 door 8v OR a 3 door 16v and then just get them side by side, and swap my coilovers and exhaust over, to give me the new car, modded as this one is, and the old car, back to standard.
Question is, if i were to purchase a 3 door BLACK 16v mk3, would my sports cat and powerflow custom exhaust fit dirrectly onto it? or are the bores different? I would probably get it done by the powerflow dealer to insure i kept my lifetime warrenty. But wanted to know if it would be a problem to do or not?
Mike
Offline boneybradley
  • Back in a Mk3...
Re: 8v and 16v Cats and exhausts.....
« Reply #1 on: 27 September 2008, 13:10 »
it depends on the year of the 16v.....upto 96 the 16v used the same catalyst and will fit/should fit directly on
Offline Mikester
  • Civic Type R
« Reply #2 on: 27 September 2008, 16:40 »
if not, the difference would be minimal to be made to fit you think? baring in mind its all custom made anyway, so could just weld on another bit to make it fit maybe?
  • Back in a Mk3...
« Reply #3 on: 27 September 2008, 17:09 »
dont worry mike powerflow will make it fit!  :wink:
Offline Mikester
  • Civic Type R
« Reply #4 on: 27 September 2008, 19:39 »
good, i am soon to have the 2nd mk3. Turning into R-machines very slowly.....valver FTW in black. YUMMMMMYY!!!
Offline k4ith
« Reply #5 on: 28 September 2008, 12:57 »
THREAD HIJACK!!
On the mk3 8v what would happen if you took the cat and drilled the honeycomb centre would this be of benefit, reason i ask is iam looking to buy a 8v and today when driving the car it rattles when driving but oddly when changing gear it disappears then returns once the clutch is deppressed, owner reckons it the exhaust as he drilled it some time ago when he couldn't get the ceramic cat off?
Or is it something else??
need help as its the only thing stopping me buying it.
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
  • Back in a Mk3...
« Reply #6 on: 28 September 2008, 13:23 »
THREAD HIJACK!!
You could remove the cat internals (but dont breath in the bits that fall out as it contains enzymes that cause luckemia!) oh and it will fail the m.o.t and will change the rev range due to reducing back pressure.. i would offer £100-150 less if its a cat fault as thats what it would cost to replace
Offline k4ith
« Reply #7 on: 28 September 2008, 13:27 »
They said it passed the mot as the emmisions were low as they let it run for a while, i am thinking its the gearbox making the noise hence its ok when clutch is in.
  • Back in a Mk3...
« Reply #8 on: 28 September 2008, 13:42 »
I would say its more likely a clutch fault if it goes into gear fine and dosent wine etc?? Clutch's are around £150 fitted!!
Offline Mikester
  • Civic Type R
« Reply #9 on: 28 September 2008, 21:41 »
mines started to wineee in reverse. Never used to and is fine in forward gears :(
Rol on the valver!!
