Author Topic: Juddering under braking. And gearbox issue.  (Read 1036 times)
Offline jonb
« on: 26 September 2008, 09:36 »
Hi guys.
Just purchased a mk2 gti.
I have juddering under braking over 25mph. Maybe warped discs, but im thinking balljoint/bush issue?
Also. Im finding it hard to locate reverse, 1st and second. Sometimes fine, sometimes sticky, sometimes i cannot find it.
Does anyone have a guide to the linkage repair.
Thanks guys.
Offline Khare
  • The bear that khares
Re: Juddering under braking. And gearbox issue.
« Reply #1 on: 26 September 2008, 17:48 »
dont know about braking, but the gears sounds like you got gear linkage artheritis. A new gear linkage repair kit should help you sort the gears out.
Offline Garza
« Reply #2 on: 26 September 2008, 18:29 »
juddering under braking could be signs the wheel bearings are worn. Mine juddered when braking and going over bumps/pot holes! Fine after they were replaced.
G
mk2 Golf GTi 8v '91 (201,004 miles) & mk5 Golf GT TDI 140
Offline Jay
  • balding fat cvnt
« Reply #3 on: 26 September 2008, 19:47 »
Could also be your missing a bolt from a caliper like I was when I first got my car...  :lipsrsealed:
As for reverse, could be the 'usual' gear linkage repair kit that's needed or the gear ball repair kit to sort that (most likely the gear ball kit - it's a pig of a job by the looks of it  :grin: ).
You can pick up the kits that include the gear and gear ball repair kits for under £20 on ebay sometimes.
While you're replacing the linkage, you might as well also get a weight shift rod from the MK3, usually £5 from a scrappy or speak to Rub Johnny he often gets these.
Offline bomp
« Reply #4 on: 26 September 2008, 19:51 »
It's right under your nose http://www.golfgtiforum.co.uk/index.php?topic=33100.0
Rubjonny recommends genuine VAG over patern parts, so theses numbers are from a previous reply of his.
VAG Parts No's
191 711 574 - long shaft - £6.22+VAT
191 711 595 A - short shaft - 1.67+VAT
They're simple to replace, just flick the plastic clips open at each end, and pull off.
Your engine mounts may have a bit of play them too, there's plenty of info on how to find if there on the way out.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline jonb
« Reply #5 on: 27 September 2008, 11:19 »
Hi guys
Thanks very much!
Although i forgot to mention that the clutch has around 3 inchs of play before the cable pulls on the clutch fork....
Offline Jay
  • balding fat cvnt
« Reply #6 on: 27 September 2008, 12:05 »
Hi guys
Thanks very much!
Mines also got some play, though I've never measured it ...
Offline Diamond Hell
  • Opinions я Us
« Reply #7 on: 27 September 2008, 12:27 »
If there's a load of play in the clutch cable it could be that which is shagged, or the clutch itself.  Either way if you're not getting a full release of the clutch then this would cause engagement issues.  Check this before buying a pile of bits that might be unnecessary.
