Golf mk2
'o' ring on blue temp sender
Topic: 'o' ring on blue temp sender (Read 1183 times)
slammed-gti
if only everything in life was as reliable as a vw
25 September 2008, 20:57 »
i got a new o ring today, but i can't get the sender to sit low enough to put the clip on now
should i have to push on it real hard?
i'm worried about breaking something else
2pac
GTI forum regular
Re: 'o' ring on blue temp sender
25 September 2008, 21:27 »
yes, you should push it hard but not brutally.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
26 September 2008, 08:31 »
fit the o'ring to the sensor first to make sure its fully seated, then firm pressure should be enough to get the sensor in.
slammed-gti
26 September 2008, 09:27 »
thanks I'll go do that right now
thank you
Kelly
2pac
GTI forum regular
26 September 2008, 21:41 »
put it in 2 stages:
first lay the sensor into the hole with the o ring on it.
second, apply a slight pressure to feel the resistance of the o ring until it's in place.
(now these words are in the right thread
slammed-gti
26 September 2008, 22:42 »
lol got it thanks a bit of a squeeze tho
raks.2008
GTI forum regular
1992 MK2 16V
Reply #6 on:
28 September 2008, 16:13 »
Sorry to be a dumb nut but where abouts is the Blue temperature sender? Is it anywhere under the dizzy?
Thanks
byebye
Reply #7 on:
28 September 2008, 16:55 »
no its blue and above the dizzy in the centre of the engine bay, well on a 8v anyway
Golf mk2
