Author Topic: Ecu swap?  (Read 667 times)
Offline Rodriguez
Ecu swap?
« on: 25 September 2008, 19:50 »
Hi all.
Any considerations I need to make when swapping a digifant ecu??   I have an aftermarket immobi fiitted and don't want to leave myself stranded.
Offline cняis
Re: Ecu swap?
« Reply #1 on: 26 September 2008, 00:04 »
aftermarket imob's wont be wired directly into the ecu, usually just the ignition/fuel pump circuit. all golf digifantII ecus are backwards compatible, whether it be bosch, siemens or TAN  :smiley:
if your old ECU is dead, remember to nick the ignition module off the top of it (held on with 2 bolts and has a wiring connection on it), always ideal to have a spare  :wink:
