Author Topic: coolant leak  (Read 726 times)
Offline 2pac
coolant leak
« on: 25 September 2008, 14:39 »
hello
i got a coolant leak somewhere from the front flange, only when the engine is off apparently.
replaced the seal for the bottom sensor and it's still leaking.
could it be the flange itself that's cracked?
Re: coolant leak
« Reply #1 on: 25 September 2008, 14:45 »
could be, they're known for it. cheap from VAG!
Offline 2pac
Re: coolant leak
« Reply #2 on: 25 September 2008, 14:57 »
thx.
as i'm using only the temp sensor, can i go for a flange from fuel injected models?
i understood they have only 2 sensors.
Re: coolant leak
« Reply #3 on: 25 September 2008, 15:01 »
the coolant connections on the inj models are different as well, extra one for the oil cooler!
Offline 2pac
Re: coolant leak
« Reply #4 on: 26 September 2008, 13:42 »
f
« Last Edit: 26 September 2008, 21:40 by 2pac »
