Author Topic: Another Mk2 2.0 8v conversion question?!?!?  (Read 1463 times)
Offline plasticfantastic
« on: 24 September 2008, 16:37 »
Hi all,
i have tried searching for as much info as possible on this topic before i asked this, but i still have a few questions for u all.......... sorry if any of it has been mentioned already!? :shocked:
Im just about to pull the engine out of my 8v GTI (once the rest of my bits get delivered), i have only recently bought the car and aparently the engine was rebuilt 20,000 miles ago, and a piper 276 cam and vernier pulley fitted and the head has been ported and polished. i have just bought a 4-2-1 stainless manifold for it, along with these mods i am considering converting it to 2.0ltr while the engine is out, but what i really want to know is what kind of gains am i likely to expect from the conversion?!
If i do go for the conversion, will any 2ltr block do?! (i saw someone on here mention a short block?!)
all help much apreciated
cheers
Offline Diamond Hell
  • Opinions я Us
Re: Another Mk2 2.0 8v conversion question?!?!?
« Reply #1 on: 24 September 2008, 16:41 »
2E or AGG bottom end.
The AGG is better as it has a crank position sensor.  This means you can fit more advanced management at a later date, should you so wish.
You should expect more torque and driveability after the conversion, as it is a longer-stroke motor.  I wouldn't get too excited about the on-paper gains though.
« Reply #2 on: 24 September 2008, 16:46 »
cheers for your help!
how would i distinguish between a 2E or AGG block?!
are they only available from a Mk3 GTI?!
thanks again
  • Opinions я Us
« Reply #3 on: 24 September 2008, 19:25 »
2E is probably the more common.  It's in Passats, Golfs, Skodas and Seats of a certain age.  The AGG is basically the later version.  I found mine in a 1997 Toledo 2.0i Sport and I suspect you'll find it in a wide variety of VAG group metal.  It'll quite possibly be cheaper out of Skodas and Seats, too.
Offline nealey
« Reply #4 on: 24 September 2008, 19:45 »
There is also an ADY engine which you can use, if using the ADY or AGG you will need to use a 2E dizzy to get it to run properly on mk2 management
There is also the bubble block which iirc is coded 3a but im not 100% on this
Offline danny_p
« Reply #5 on: 24 September 2008, 21:10 »
bubbel block  is a bit rare and expensive,  it's found in audis    same block hight as the 1.8 so has short rods
all the VW's have gone bar 1.
Offline Jay
  • balding fat cvnt
« Reply #6 on: 24 September 2008, 23:02 »
« Reply #7 on: 24 September 2008, 23:39 »
Cheers for all your help!  :wink:
much apreciated!
« Reply #8 on: 25 September 2008, 10:29 »
is it the AGG code block that has the wrong dizzy for mk2 managment, or is it the other later one?
