Author Topic: (HELP) ENGINE CONVERSION 2.0 8v from a mk3 on carbs?????  (Read 4486 times)
Offline Grizzle
Right then, i curently have a 1.3 but im after abit more power.
i have a 1.8 driver that a brought for the engine n lil bits and bobs
and also a set of twin weber carbs..
my plan was to run a single webber on the 1.8 and just slide that it.
but ive been offerd a mk3 gti for £300 and its a mint runner.
Would i be best just throwing the 2.0 as it is or putting the 1.8 head on?
would it bennifit if i ran it off twin carbs?
or is it just too much hassle to change the 2.0 to carb, should i just keep with the 1.8 idea?
HELLLLLP  :undecided:
Cheers guys
Its a dub thing!!<br />
Offline Diamond Hell
  • Opinions я Us
Re: (HELP) ENGINE CONVERSION 2.0 8v from a mk3 on carbs?????
« Reply #1 on: 24 September 2008, 12:17 »
Put the 2.0 2E block under the 1.8 head (or even better a PB GTI head) and fit the Weber carb to it.  Are you talking about a twin-choke Weber carb - the 32/34 DTML unit, rather than 'twin carbs' which would be an utter ballache to fit to a counterflow engine?
Conversion to injection would be a lot more involved, including fitting a lift pump into the tank etc etc.  The 2E motor has funny-shaped ports and it's probably also running a cat and lambda, too.
I have a relatively fresh 1.8 lump with a GTI head on it sitting around, which you'd be welcome to for £50 to get it out of my workshop.
Offline Grizzle
« Reply #2 on: 24 September 2008, 12:27 »
yehh ive got two 32/34 DTML carbs, i wanst sure but i was guessing i could run them together.
but i was told it would be pointless on the 1.8, would benefit better from a single unit.
cus i can get things like a manifold made to fit the webbers by my mate
i just wasnt sure if i could just bang the 2.0 in with the 1.8 driver head. put the webers on and be away.
no idea if its possible or worth it??
  • Opinions я Us
« Reply #3 on: 24 September 2008, 14:05 »
If you're going to that trouble then get an ABA 8V crossflow head, get the oil return welded up and redrilled appropriately, a little light head work and then hang carbs off the front of it.
If you're going to all that trouble then you may as well find a set of bike carbs and get your mate to make up a stub manifold for them, as they're more accurate and will flow air better than a pair of elderly Webers...... but if you're going that far then you may as well do things properly and get an electronic injection system on the motor.
Offline danny_p
« Reply #4 on: 24 September 2008, 19:00 »
32/34 dmlt webbers won't work well as a pair,    you need to feed 1&4 from one carb and 2&3 from th other   then try and balance the carbs.   that just ain't going to happen
all the VW's have gone bar 1.
