Author Topic: koni fsd  (Read 5545 times)
Offline candy turbo
Re: koni fsd
« Reply #10 on: 24 September 2008, 20:22 »
I have taken a few other members and even Kev from Revo - they all commented how well it felt and expected it to be worse but it wasnt the case.
hi neg , have you got any pics of your car mate apart from the ones on your sig ?
clubsport S no 215
Offline neg
Re: koni fsd
« Reply #11 on: 24 September 2008, 20:30 »
You have PM
Offline candy turbo
Re: koni fsd
« Reply #12 on: 24 September 2008, 20:43 »
cheers mate ,looking good !!  how many mm did the set up you have lower it ?  i m not sure if the gti and the edition 30 have the same ride height as standard, i was led to believe the ed30 was 15 mm lower than a gti to start out ?? :undecided:
this is standard apart from 10 mm rear wheel spacers
« Last Edit: 24 September 2008, 20:47 by candy turbo »
clubsport S no 215
Offline neg
Re: koni fsd
« Reply #13 on: 24 September 2008, 20:47 »
GTI and Ed30 have identicle suspension from factory which is lower than the normal golf by approx 15mm
I think it was about 20mm by the end of it, enough to look better but not cause any problems, have had a full load and get no rubbing etc - bear in mind I am runnign 19's you will be even better with 18's
Offline RedRobin
Re: koni fsd
« Reply #14 on: 24 September 2008, 20:48 »
....The Ed30 and GTI have the same ride height and that is 15 mm(?) lower than the standard Mk5 Golf. I don't know what the GT ride height is.
Offline candy turbo
Re: koni fsd
« Reply #15 on: 24 September 2008, 20:57 »
so what springs are you using ?
clubsport S no 215
Offline neg
Re: koni fsd
« Reply #16 on: 24 September 2008, 21:31 »
H&R, I was going for Eibach but it was when there were production issues with the rear springs so after a lot of research I opted for the other popular choice which was H&R - probably more popular over in the states which is where I got most the info from.
Offline gazbutmk5gti
Re: koni fsd
« Reply #17 on: 24 September 2008, 23:48 »
A lot of research :grin:, you just let me do the donkey work :laugh:
Revo stg2+ & lots more
Offline candy turbo
Re: koni fsd
« Reply #18 on: 25 September 2008, 07:06 »
what set up do you recommend gaz ? yours had the stance spot on imo     cheers  :smiley:
clubsport S no 215
Offline neg
Re: koni fsd
« Reply #19 on: 25 September 2008, 10:28 »
Ah yes, Gaz having the problems with the Eibach rears which saved me a LOAD of hassle  :smug:
