Author Topic: Serious Problems with the valver...  (Read 1216 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 23 September 2008, 12:23 »
Im trying to get my valver conversion to turn over but its not having any of it!
This is the problem im having.
When the battery is connected the windscreen wipers come on - even with the ignition off... The switch makes no diffrence they stay on untill the battery is disconected.
The hazards and full beam are staying on regardless of what i do but the hazards or on constant with no flashing.
When i go to turn the ignition on,  nothing happens what so ever, no warning lights.. nothing.   When i go to start the engine.. nothing happens.
Any ideas whats going on here?  I cant put my finger on it, everything is conected as it should be,  the only thing is there are a couple of switches etc.. which are not pluged in yet like the rear window heater etc..
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
Re: Serious Problems with the valver...
« Reply #1 on: 23 September 2008, 12:27 »
re-check the wires....sounds like something is plugged in wrong (fusebox??)
kells
« Reply #2 on: 23 September 2008, 12:44 »
sounds like a earth problem to me??
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 23 September 2008, 17:35 »
hazards on constant would be a relay?!??! i really dont know, so i'll shut up, you know more than me, ok enough..... :lipsrsealed:
Offline Rmachines
« Reply #4 on: 23 September 2008, 17:53 »
yea a relay would cause it but this is diffrent, its a total messup of electrics,  im only good with old ford electrics  :grin:
Offline grimmer
  • www.check-light-on.co.uk
« Reply #5 on: 23 September 2008, 21:42 »
sounds like u have problem with the positive battery side of the starting motor wiring, can cause many strange problems when u turn the key, if not can be a earth fault, wouldnt of thought it would be a fusebox problem as the connectors only connect one way into the fusebox.
MK3 GOLF GTI 8V  now converted to 16v!!
Offline Rmachines
« Reply #6 on: 24 September 2008, 12:02 »
Yea i know you cant really go wrong with the fuse box, its possible the starter wiring is wrong, it was so long between taking it off and refitting the engine i forgot everything.  I need to get some pictures i think.  :grin:
Offline Rmachines
« Reply #7 on: 24 September 2008, 15:25 »
All the starter wiring is ok now,  i did make one mistake, i put the earth from the battery to the stater motor bolt insted of the bell housing but still made no diffrence when i changed it.
The dials dont come on as they should, the milage etc.. doenst show up but the indicator and full beam lights stay on constantly, and the winds screen wipers wont stop.    cant figure it out.
Offline Rmachines
« Reply #8 on: 24 September 2008, 18:28 »
Ok well basicly VW are very very stupid people...   or i am.
They wont allow any of the plugs to be connected to the wrong holes... accept the Main + and Main - feed which can be put in the oposite holes on the fuse box... and i did exactly that.
Now the indicators work perfectly,  but... nothing else does.   The starter will click and then click off and it will do it only once ...  i have to take the battery off and reconect to make it do it again.
Still no milage on the dials.
Indicator stork has no effect, so no switches work.
EDIT- I now have milage, but no warning lights with ignition.   If i turn the key the solonoid click and the milage goes off the dials untill i reconnect the battery.
« Last Edit: 24 September 2008, 18:31 by Rmachines »
Offline Rmachines
« Reply #9 on: 24 September 2008, 18:39 »
Ok... Another update  :grin:
The car is now turning over on the key... but there is no warning lights what so ever.  Only indicators work.    Other than that so far it seems ok.
