Had mine on VAGCOM again the other day Luca, to try and find out what this flatspot around 5500rpm is..
All vagcom readings were fine and Corey seems to think it's turbo lag as it seems to be straight after the up change (only really noticable in higher gears). When running tests through each gear it never does it, only when upshifting when giving it hard beans..
It's due it's first service in 2 weeks, so hopefully they may sort it then. Maybe a dodgy DV or something, unless anyone else knows what it is?
