Author Topic: quick detailer in bulk?  (Read 3130 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 22 September 2008, 18:24 »
can you buy this stuff in concentrated form so you can dilute into your own trigger spray?
Seem to be going though gallons of the stuff!!
I've seen the Last touch stuff on Elite, are there any others?
NewGolf
Re: quick detailer in bulk?
« Reply #1 on: 22 September 2008, 18:37 »
Last Touch is great, even watered down to 3:1 with De-Ionised water, making almost 16 litres for under £20! There are others like Chemical Guys which are just as good, but Last Touch is my fav.
It works out a LOT cheaper buying it in bulk.
http://www.cleanyourcar.co.uk/detailing-sprays/meguiars-last-touch/prod_225.html
http://www.cleanyourcar.co.uk/valeting-and-bulk/chemical-guys-synthetic-quick-detailer-1-gallon-/prod_448.html
HTH  :smiley:
« Last Edit: 22 September 2008, 18:44 by NewGolf »
Offline rowlers
« Reply #2 on: 22 September 2008, 18:45 »
I didn't realise it could be diluted! That does make it good value then!!
Cheers NewGolf :wink:
NewGolf
« Reply #3 on: 22 September 2008, 18:55 »
It certainly can! I use it 3:1 with no problems.
Make sure you use De-Ionised or Distilled water as normal tap water is full of minerals that could cause spots. If you cant get hold of any, use water from a Brita Water Filter. Most supermarkets have some, cheap as chips!
If you are claying, Bilt Hamber do a clay that only needs plain water as lube, Autoclay
http://www.elitecarcare.co.uk/product_info.php?cPath=27&products_id=455&osCsid=28acb39dd6771472095e0ae3cb58846c
 :smiley:
