Author Topic: Driveshaft spline keeps snapping! What would cause this???  (Read 3009 times)
Offline AudiA8Quattro
Re: Driveshaft spline keeps snapping! What would cause this???
« Reply #10 on: 24 September 2008, 11:48 »
I would always recommend using a press to do a front wheel bearing, it is possible to use a hammer/socket to remove and a vice to fit the new one, however the chances of doing any damage is far less with a press.
What torque setting are you using on the hub nut? It could snap the splines if its been overtightened. Just a thought.
