Author Topic: Lets get dirty! Show off your engines!  (Read 4874 times)
kells
Re: Lets get dirty! Show off your engines!
« Reply #10 on: 22 September 2008, 17:06 »
It's interesting to see how many cone filters are out there, which apart from an awesome noise [fair comment] does bugger all for performance based on the engine breathing in hot air from the surrounding block etc cold feed or not.  :sad:
well it made my car drive a hell of alot better, alot smoother, and they aint quite as pointless as the drilled airbox and 50 quid replacement filter route hahaha :grin: :grin:
Offline Vdubbster
« Reply #11 on: 22 September 2008, 17:40 »
I've got one of them too!! The crazy purple bobby thing! Also got a battery cover too! :D
Vdubster - nice job on the manifold, how long did that take & what did you do??
This took the pi33, I just got the sand paper out and started to sand 80 grit to about 600. I used some sanding mop type things on my drill where I could. But the tight areas are an arse. But looks good, just need to do the rocker cover
Then used a polishing mop set from ebay which was about £15.
Offline MrTurner
  • Facelift leon cupra
« Reply #12 on: 22 September 2008, 17:57 »
 :shocked: There are some tidy engine bays out there!  Are they just cleaned/sanded to be so mint, or are new/replacement parts needed along the way?  Can see me going this route..
kells
« Reply #13 on: 22 September 2008, 18:07 »
mine is all the OE parts, which were alot worse for wear than any iv seen on here yet..took my engine to bits basically....
Offline MrTurner
« Reply #14 on: 22 September 2008, 18:27 »
You must have a lot of time on your hands  :grin:  I think engine out would be the only way.  No idea how I'm going to explain that to the missus..
kells
« Reply #15 on: 22 September 2008, 18:46 »
engine dont have to come out, mine didnt and its mint now....has taken a yearof messing about and im still on it now, do it as and when i can, i lead a busy lifestyle so its hard to get the time in
a few more of mine... with the only new part added to the bay, a new coolant bottle  :grin: :cool:
« Last Edit: 22 September 2008, 18:50 by kells »
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #16 on: 22 September 2008, 19:42 »
I'm embarrassed to show mine coz it's totally standard, dirty and I can't be 4rsed to clean it. But then again mine is not for show, it's a daily workhorse. Next year...  :embarassed:
Keeping schtum. Mostly.
kells
« Reply #17 on: 22 September 2008, 20:01 »
my Gti is also my daily hack, other car is even cleaner under the hood
Offline Stu G
« Reply #18 on: 22 September 2008, 20:46 »
yours is inspiriation for us all that use ours as daily drivers. ive gotta go through a rebuild first though. my valve stem oil seals are on the way out and it aint good.
Offline madhouse
« Reply #19 on: 22 September 2008, 21:15 »
This is just pure class - awesome!!  :cool:
