Author Topic: Bong on corners  (Read 3227 times)
Offline stealthwolf
Bong on corners
« on: 21 September 2008, 21:39 »
I've noticed this only twice but if I go round a corner (~90*) at some speed, the car makes a 'bong' sound. It's the same sound it makes when you leave the handbrake on or the door isn't fully shut. It's only made the sound once on the two occasions this has happened.
Any idea what this is?
No indication on the screen.
Offline SteveP
Re: Bong on corners
« Reply #1 on: 21 September 2008, 21:53 »
Did you have anything on the passenger seat???
If so then it would be the seat belt warning.  :smiley:
WhiteGTI
Re: Bong on corners
« Reply #2 on: 21 September 2008, 21:58 »
I have had a"bong" noise which is the same as the handbrake noise when accelerating hard on very rough road surfaces.
That probably doesn't help you, but i guess confirms to you that others also experience this noise!
Offline mad man gti
Re: Bong on corners
« Reply #3 on: 21 September 2008, 22:05 »
mine does that when i am driving on its  limit..... it tells me to calm down.
Offline Saint Steve
Re: Bong on corners
« Reply #4 on: 21 September 2008, 22:06 »
maybe the esp playing the trick. Try it without and see if you can get it to re-produce, without loosing control in doing so of course.  :smiley:
Offline 182_blue
Re: Bong on corners
« Reply #5 on: 21 September 2008, 22:08 »
a warning noise telling your about to take off so put your seatbelt on
 :laugh: :evil:
Offline Top Cat
Re: Bong on corners
« Reply #6 on: 21 September 2008, 22:13 »
  you only get it on the watercooled v-dubs its warning you of water spillage.
Offline SteveP
Re: Bong on corners
« Reply #7 on: 21 September 2008, 22:14 »
Is it your turn to be on the pop tonight then TC ?? :laugh: :laugh:
« Last Edit: 21 September 2008, 22:17 by SteveP »
Offline Saint Steve
Re: Bong on corners
« Reply #8 on: 21 September 2008, 22:15 »
 :shocked:
yes im endangering loosing fluids here too after that photo!  :drool:
Offline stealthwolf
Re: Bong on corners
« Reply #9 on: 21 September 2008, 22:17 »
Rofl. Anyway had a sit on the throne and suddenly thought about fluids. Is it possible that I swung so fast round the corner, it made it appear like there was low fuel/washer fluid/oil?
