Author Topic: front electric windows dont work (1997 mk3 golf cl)  (Read 1955 times)
Offline yerino
« on: 21 September 2008, 17:31 »
anyone had this problem?? know wht it could be?
im hoping the wires are jus a bit tight inside the door and have snagged but ill take the inside of the door of tomorrow and have a look. any advice on how the inside of the drivers door comes off?? i cant see any screws. lol
also anyone know where i can buy an induction kit for my car? thanks
Offline Diamond Hell
  • Opinions я Us
Re: front electric windows dont work (1997 mk3 golf cl)
« Reply #1 on: 21 September 2008, 21:09 »
If the electric windows have stopped working then you'll need to scrap it.
(anything to get Golf3s off the road).
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 21 September 2008, 21:22 »
*I could say many things here!! but the filters won't let me!*  :angry:
Offline xkaty_h
« Reply #3 on: 21 September 2008, 23:56 »
might be the motor.
Thats wahts gone in my MK2
Offline caddy vantastic
« Reply #4 on: 22 September 2008, 16:44 »
Does the passenger window work from the passenger switch. Switches are common as hell to break on those mate.
To much going on to list all the work
Offline robiwill
« Reply #5 on: 27 September 2008, 08:39 »
on a 1997 you should have total closeure fitted to the windows to see if its a broken wire there are two things to check.
1 hold the key in the drivers door lock in the open position and all your windows should open including the sunroof if fitted. if they dont check the central locking pump has a 12 pin connector.
2 when you operate the switch in the door is the motor clicking if so its a loose wire or worse as in the case of my mothers mk3 se the cable had jumped the runner.
90% of the time with MK3 electric windows its a loose wire
