Author Topic: 1.8l fueling problems - backfires.  (Read 1245 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 19 September 2008, 22:38 »
Hey,  i seem to get alot of backfiring when decelerating down a hill for example,  i know its normal for a bit but i get a lot,  but whats worse is when i start the engine it splutters a bit and i have to give it a bit of throttle to get it running properly,  now recently when i do this i get a big BANG and a splutter,  obviously this is overfueling a bit,  its just passed its emissions (Just about)  so it cant be to bad.
all i get on VAG-COM is air temp sensor but i cant see that causing this as it runs ok.
any ideas what it could be?
cheers.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
Re: 1.8l fueling problems - backfires.
« Reply #1 on: 19 September 2008, 23:32 »
my old driver did similar and a new temp sensor sorted that (oh and check the breather pipes as I had several failures on mine making the emmisions higher and the idle lumpy)
Offline Rmachines
« Reply #2 on: 19 September 2008, 23:58 »
I changed the temp sensor when i got the car,  the breathers were cleaned also. its the Air temp sensor i think could be a problem but idle is fine and Air temp sensor causes bad running usualy.
Offline Rmachines
« Reply #3 on: 20 September 2008, 21:21 »
any one else any ideas?  :smiley:
Offline davero
« Reply #4 on: 21 September 2008, 13:31 »
I would check all your vacumn hoses again. Really does sound like the symtoms of a split hose
  • Back in a Mk3...
« Reply #5 on: 21 September 2008, 14:59 »
on the rear of the engine (going by memory its just under and to the left of the s.p.i unit?) there is a breather that has a 1 way valve (with 2 green bungs in)... check this as if the valve dosent work right or the bungs let air out...this can cause similar issues.
Offline Rmachines
« Reply #6 on: 21 September 2008, 16:06 »
ooo i will check that out!  Thats a possibility.  :smiley:
