Author Topic: Rubbing noise????????????????  (Read 911 times)
Offline Ciderdan
« on: 18 September 2008, 20:03 »
Bit of a funny one.  On full right lock there is a sort of rubbing noise coming from the other (passenger) wheel. It doesnt 'clunk' like you would probably expect from a CV.   It only happens at low speeds, although there might be a bit of a whistling noise when turning at speed. Bearings seem fine.  Nothing is obviously loose.  No obvious signs of rubbing anywhere either.  Could it be a CV?
All ideas greatly received.
Keep the Faith
Offline Dec
Re: Rubbing noise????????????????
« Reply #1 on: 20 September 2008, 08:52 »
Is your car lowered? Could be the tyre rubbing on the arch?
Offline kittie
« Reply #2 on: 20 September 2008, 17:56 »
What wheels have you got as well, are they wider than normal or funny offset?
« Reply #3 on: 22 September 2008, 11:01 »
have a good look at the cv boot, around the anti roll bar mountings. there isnt much clearance around there!  I also had the tyre rubbing on the inner arch thanks to the haynes giving me the wrong lengths for the passenger fixed track rod  :angry:
