Author Topic: how many amps through the battery cable  (Read 1093 times)
Offline Dolly
« on: 17 September 2008, 21:41 »
does anyone know what my main battery cable from alternator, to starter, to battery should be rated at? ive had to turn the battery through 90 degrees on my G60 to avoid the boost pipe and need to get a longer cable from the starter to the battery, around 200-300 longer.
ive got one for 110 amps but it seems too small.
Offline danny_p
Re: how many amps through the battery cable
« Reply #1 on: 18 September 2008, 01:12 »
starter is rated at 1.2 kw iirc   cable you have is probaly 16mm2 whitch will be fine,   starter cables are generaly quite small for the current they carry as they ain't very long and they don't do it for very long.  alternator's are normaly 60 A or 90 A,    just ensure  you get good connections as that where  most ppl cause themselves problems
all the VW's have gone bar 1.
Offline Dolly
« Reply #2 on: 18 September 2008, 20:41 »
yeh i got 16mm 110 Amps, i figured the amp rating would be ok but it just looked skinny, ill have a go with it.
Offline danny_p
« Reply #3 on: 19 September 2008, 00:18 »
ive used 16mm2 for starter/ battery relocation cabel on quite a few landrover v8 conversions allays been fine   good for 400 amps on starting circuits.
