Author Topic: Vac leaks.  (Read 1014 times)
Offline Rodriguez
Vac leaks.
« on: 16 September 2008, 20:40 »
Has anyone here got a foolproof method for checking for vac leaks.  I'm pretty sure that my popping overrun and slight 'cough' on hard acceleration is down to this.  I had similar niggles with my vr6, but in both cases the pipes all look ok, new even.  Would a lack of back pressure at the exhaust cause this?
Also, while I'm at it... I'm in the market for a rainbow drivers seat (vgc) as my reconditioned one was done on the cheap I reckon.
Offline Conker
Re: Vac leaks.
« Reply #1 on: 16 September 2008, 23:24 »
Submerge the pipe in water and blow down it with your finger over the other end.  Look for bubbles!
Offline rowlers
  • I'm back - MK7 GTI
Re: Vac leaks.
« Reply #2 on: 17 September 2008, 17:17 »
I've read somewhere about using a butuane torch (not lit obviously!) and blow butane over all pipes, listen for the engine revs torise and oyu find oyur leak, a lot cleaner than using WD40 etc..
Just not sure how safe this might be?!??!
Offline Mr Blue
Re: Vac leaks.
« Reply #3 on: 17 September 2008, 18:08 »
That butane sounds interesting.
I dont get how the WD40 trick works? anyone? :smiley:
Was thinking fairy liquid but its a vacume system
Offline rowlers
Re: Vac leaks.
« Reply #4 on: 17 September 2008, 18:19 »
WD40 - spray over vac pipes with engine running, revs rise when leak found, but of course you have WD40 all over the engine bay!!!
Leon R
Re: Vac leaks.
« Reply #5 on: 17 September 2008, 18:48 »
Brake Cleaner or Carb Cleaner works the same as WD40 but then evaporates after. Be sure not to spray on electrical connectors or something hot like the exhaust manifold, just to be on the safe side. Works exactly how Rowlers described
« Last Edit: 17 September 2008, 18:59 by Leon R »
