Author Topic: backfire or something?  (Read 1617 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 16 September 2008, 18:04 »
first prob I've had for ages, so here goes :wink:
last couple of week, the valver hasn't started in the button, taking a couple of extra seconds to start but thought nothing of it.
it also smells a bit rich.
during warmup I get slight backfires, after coming off the trottle while still in gear. The rev counter is behaving oddly, it either plummets straight to 0, or lifts up a bit then pmmets to 0, but the engine doesn't die nor do any ignition lights come on?!?
As soon as it is warm COMPLETELY NORMAL running returns!
First thought it may be a vac leak on the overrun circuit, but ruled this out as it stops when warm, then thought about the warm up circuit i.e. cold start value putting too muh fuel in???
Also thought about the plug leads, (dizzy cap plugs and rotor arm are new),
As said it runs/revs/pull great once warm.
Any clues folks?
Offline Mr Blue
Re: backfire or something?
« Reply #1 on: 16 September 2008, 18:11 »
The revs bouncing up/down may be a faulty dizzy. I had this similar problem.
Offline rowlers
« Reply #2 on: 17 September 2008, 16:59 »
wat about the coil anyone think this could be the cause?
Offline 1982.rpd
« Reply #3 on: 17 September 2008, 18:40 »
First check all the earth terminals and do this:
http://www.golfgtiforum.co.uk/index.php?topic=56707.0
Offline rowlers
« Reply #4 on: 17 September 2008, 18:55 »
Tried the earths, all look OK.
next?
Offline 1982.rpd
« Reply #5 on: 17 September 2008, 20:12 »
Clicky linky ^^^^^ :wink:
Offline rowlers
« Reply #6 on: 17 September 2008, 21:41 »
hey, thats MY how to :grin: :grin: :grin:
No its deffo not the timing :wink:
Offline 1982.rpd
« Reply #7 on: 17 September 2008, 22:03 »
Rowlers u the man!  :grin:
Offline rowlers
« Reply #8 on: 19 September 2008, 17:49 »
come on folks gives a bit of help!
My car is blowing itself to bits here!!
Stalled today, then had smoke come from under engine, opened bonnet, smoke was coming from airbox, overrun cut off valve area. Started it up when smoke cleared, and then got it warmed up (whilst backfiring in Asda carpark!). Once warm it runs really well.
Checked VAC pipes around ORCO valve, all OK, Plug leads look good, dizzy will be check in 10 mins.
I'm also going to back the timing off a bit, and weaken the mixture slightly.
any more idea before it goes to the scrap heap!!!
Offline 1982.rpd
« Reply #9 on: 19 September 2008, 17:53 »
ISV,  CO mixture, warm up regulator?
