Author Topic: MK3 in the wet  (Read 1660 times)
Offline golfwannabe
MK3 in the wet
« on: 16 September 2008, 14:22 »
Hi,
Has anyone ever noticed their mk3 trying to stall in the wet?
I've noticed sometimes when its raining, that coming up to a junction, drop the clutch - the revs will drop too low and the car will cut out with just the oil light coming on - it will always fire back up straight away though.
Don't think this is related to the other stalling topics is it????
Is there anythin under the hood that when wet will cause cut outs?
Any help / remedies really appreciated.
Thanks as always.
Offline jafo
Re: MK3 in the wet
« Reply #1 on: 16 September 2008, 14:39 »
I know a lot of them with ignition coils suffer becuase the water makes it arc out and thefore no spark is sent to the plug.
If you have an ignition coild take it off and clean it, then spray it with some black heat resistant paint, then some kontact sl (from Wurth)
Its a laquer which will seal it and form a clear water resistant layer.
Hope this helps.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: MK3 in the wet
« Reply #2 on: 16 September 2008, 15:47 »
What jafo says is correct,  there is something that might make it a bit easier this is something we do as part of a service in the garage,  Get some silicone spray and spray the whole engine every conector and electrical part you can find! its great stuff.
When the bloke used to come and try to sell it to us in bulk, as a test he would get a tank of water and a live mains light bulb, he sprayed it with this spray and grabed it with his hand and dunked it in the tank, sure enough the bulb worked, he didnt die and nothing shorted out.  of course hes not alowed to do it now but.. the point is it really does a good job of keeping water out!!!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline golfwannabe
Re: MK3 in the wet
« Reply #3 on: 16 September 2008, 19:20 »
cheers for the replies.
Where can you get silicone spray from? Any recommended brand?
Can i just literally spray the whole engine?
cheers
Offline SL25
Re: MK3 in the wet
« Reply #4 on: 16 September 2008, 21:08 »
I'd be interested in the silicone spray too as mine does this when it's damp...
Where do you get the stuff from??
MKIII 8v GTi - Standard
Offline bored_Welsh_lad
Re: MK3 in the wet
« Reply #5 on: 17 September 2008, 12:43 »
any automotive store should sort you out!!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline b16dev
Re: MK3 in the wet
« Reply #6 on: 09 October 2008, 23:29 »
my car does this 2, but this only happens when Ive not derived it for a few days, and only does it when the engine is cold, but if mine stalls i cant get it started for half an hour, which means i have to give it full revs for a good few miles until the car heats up, any ideas?
Offline boneybradley
  • Back in a Mk3...
Re: MK3 in the wet
« Reply #7 on: 09 October 2008, 23:33 »
could be a dirty isv or temp sensor?? clean the isv and if that don't work replace the temp sensor
Offline b16dev
Re: MK3 in the wet
« Reply #8 on: 15 November 2008, 17:04 »
where is the isv sensor?
Offline golfwannabe
Re: MK3 in the wet
« Reply #9 on: 16 November 2008, 15:44 »
Nah.
Mine was bloody throttlebody - did the old clean out and now is fine.
