Author Topic: I992 GTI 1.8 16v purchased...couple of queries.  (Read 1185 times)
Offline noj66
« on: 16 September 2008, 13:11 »
Hi folks,i recently bought the above,really enjoying driving and owning it.Just a couple of niggles so far,inevitable with a 16year old motor i suppose.
Firstly there's a high pitched whine,not that disimilar to the gearbox whine of an original mini,if anyone's old enough to remember that!I took it to my local VW garage where the guy said it's common for the gearboxes to rattle a bit on 16v's.Not a massive problem bit if there is a solution i'd like to put it right.
Secondly,much less important,the 'flaps' for the jacking points are hanging forlornly under the car.If i buy 4 new ones do you think they would stay in place?
Can see from reading the posts a lot of you guys and girls are quite good with the old spanners,whereas i'm a total 'doofus' when it comes to anythin' mechanical,so any help would be appreciated.
Offline 1982.rpd
Re: I992 GTI 1.8 16v purchased...couple of queries.
« Reply #1 on: 16 September 2008, 13:28 »
Change the gearbox oil.
Offline AdamMk2
  • Beautiful
« Reply #2 on: 16 September 2008, 19:31 »
Also a small self tapping screw between the trim  will hold them in (Obv so they cant be seen)
Dont buy new ones at £7.50 each!!!  :laugh:
Offline noj66
« Reply #3 on: 16 September 2008, 20:20 »
Good thinking,why didn't i think of that? :laugh:Cheers.Nice motor by the way. :smiley:
Offline Conker
« Reply #4 on: 16 September 2008, 23:26 »
Firstly there's a high pitched whine,not that disimilar to the gearbox whine of an original mini...
Are you sure its coming from the gearbox, and not the belts on the other side of the engine?  Could be a overly-tight or overly-loose belt.
Offline Goops
  • mk2 gti 16v
« Reply #5 on: 16 September 2008, 23:29 »
I get a squeal from the belt time to time, its deffo the tension in mine.
Check your alternator adjustor?
Offline noj66
« Reply #6 on: 17 September 2008, 13:37 »
Cheers for the replies.Yeah the belts sound a more logical explanation,shall get it looked in to. :smiley:
