Author Topic: ground clearance ??  (Read 1239 times)
Offline orbit48
  • OAK GREEN VALVER is no more.....
ground clearance ??
« on: 15 September 2008, 20:13 »
recently bought a magnex system for my mk2 16v from this forum (abingdon man-top bloke),  the only thing that worries me is the first silencer, the cherry bomb type is rarther large, it seems to hang down below the car.  i have measured the ground clearance and i only have 50mm, i've been avoiding speed bumps like you wouldn't believe................should i be worried or is 50mm clearance enough ? ? ?
Offline Khare
  • The bear that khares
Re: ground clearance ??
« Reply #1 on: 15 September 2008, 22:03 »
50mm is very close to the ground mate. I would take bumps carefully and try to avoid them! My front chin spoiler is about 50mm from the ground and i scrape on alot of stuff!
Offline AdamMk2
  • Beautiful
« Reply #2 on: 16 September 2008, 00:19 »
Dont go in Multi storeys either mate!!
Have you got heavy duty rubber things (Its late and forgot what theyre called haha) Try and get as much support as you can I would, tight to the heat shield all the way along, so it may mean changing them all.
Ive recently just replaced the middle one with a SH*t one as I was desperate for it but Im going to invest as for £7 its worth a try and theres some reassurance its a bit thicker than an Elastic band haha  :wink:
Offline 1982.rpd
« Reply #3 on: 16 September 2008, 10:08 »
I dropped my golf -60mm its quite low now and even tho I have a standard exhaust I have cable tied it up to stop it whackin every speedbump I go over :grin:
Offline Kingt_mk2
  • you could call it complex simplicity?!
« Reply #4 on: 16 September 2008, 13:30 »
i had to cable tie my zaust once, they slowly melted lol
:: 1988 Golf 1.8 16V ::
Offline 1982.rpd
« Reply #5 on: 16 September 2008, 14:05 »
Only cable tied it on the rear bracket, the rest are small zaust hangers just turned the brackets on the car 180* to lift it up a bit  :wink:
Offline gusto
  • 16v gti baby
« Reply #6 on: 16 September 2008, 18:57 »
mine is standerd and not had car lowerd and i still get the scrrrrrrting sound over most bumps its the front box just seems to be low as if it needs twisting round but then the bracket is in the wrong place pluss surrey is full of the small humps that are sump busters  :angry: :angry:
