Author Topic: Fitting new Caliper bolts.  (Read 3774 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 15 September 2008, 13:49 »
As with every golf i work on... the rear caliper bolts were siezed on mine.   As they are all a mush of metal now i need to replace them.
If i was to find some standard bolts which fit, is there any reason why i shouldnt use them?  With a dab of lock tight it should be perfecty safe yes?
cheers.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline bored_Welsh_lad
Re: Fitting new Caliper bolts.
« Reply #1 on: 15 September 2008, 15:57 »
Im thinking of doing exactly the same thing mate, im sick of the thingys rounding all the time
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Teutonic_Tamer
« Reply #2 on: 15 September 2008, 16:09 »
I would not recommend using anything other than the proper bolts.
The problem with caliper bolts is down to galvanic corrosion.  The bolts will be a different "metal" to the caliper.  Therefore, use some anti-seize paste on the non-threaded shaft of the bolt, and under the head (where it fits into the caliper), and then fully coat the threads (put enough on them to seal the entire length which screws into the hub or caliper carrier) with some low strength thread lock.  Don't use high strength thread lock - it isn't necessary, and you'll just end up rounding the heads the nex time.
Also, get a decent 6-point socket.
HTH
I feel like a homo
Offline Paul86S2
« Reply #3 on: 15 September 2008, 16:09 »
They need to be 10.9 grade steel for strength. Most normal bolts are 8.8.
Go to a good fastener supplier and they should have the right size, pitch and strength.
Size should be M10 x 1.25 x 21mm.
Paul
« Reply #4 on: 15 September 2008, 16:46 »
i was thinking of a yaughting chandlery tbh... some marine grade bolts should hold up fine
Bumper Vents :D
VW BUSH
« Reply #5 on: 15 September 2008, 19:34 »
Galvanic corrsion, now thats somthing you dont hear every day!
You are correct though, copper slip and a good quality socket driver all thats needed.
I got Unbrako bolts in mine which i robbed from work
And i use Kluber anti seize paste on everything under the car or which is a Mofo to get off ie manifolds zausts  saves on knuckle skin :laugh:
« Reply #6 on: 15 September 2008, 22:05 »
Got a link to that Kluber stuff?
I use Bostick Never-Seze - but it is firkin expensive, and hard to get hold of.  Much better than any copper based stuff though.
I feel like a homo
VW BUSH
« Reply #7 on: 15 September 2008, 22:44 »
http://www.klueber.com/Anwendungen/Klueber_anwendungen_startframe.htm
Kluber are the best lubricant co going ive been using their high temp anti seize for years up to 1200c! got loads of special industrial
stuff which i use on me car, it pays to be the Engineering Manager :laugh:
Offline Rmachines
« Reply #8 on: 15 September 2008, 22:45 »
i will visit a few places tomorrow and see what i can come up with.  would 8.8 be ok ?  surly if i did them up tight its not going to go and fall out is it?
cheers.
VW BUSH
« Reply #9 on: 15 September 2008, 22:49 »
Trago Mills down on the Liskeard to Bodmin road sell Nuts n bolts
Its like pound shop heaven, Proper job
