Author Topic: Gearbox Advice  (Read 5691 times)
Offline daros
Re:Gearbox Advice
« Reply #10 on: 19 July 2004, 19:06 »
Massive thanks for your help guys. Having spoken to the bloke that fitted it he assured me it is indeed a GTi box but one from a 2litre mk3 gti. Does this explain what i am now finding?. He advised holding the gears a little longer, so on the way home from work i did and it wasn't as bad as i first thought. Still not as responsive as with the old box....just looks like i'll have to adjust my driving style lol.
On the plus side, my new box has only covered 30K thus far so should be good for the life of the car now :)
Offline Gambit
Re:Gearbox Advice
« Reply #11 on: 20 July 2004, 09:16 »
mk2's use a rod change box
mk3 gti's have a cable change box, so in order to run that box in the mk2 he'd have needed to change the pedal box also. and i doubt he done this as it would be too much hassle
if i were you id get under the car sharpish and find out what code is stamped there
Re:Gearbox Advice
« Reply #12 on: 20 July 2004, 09:57 »
I thought only the later MK3s were cable change?  Probably talking rolocks ;)
golfvr6
Re:Gearbox Advice
« Reply #13 on: 20 July 2004, 10:15 »
I think rub is right.
Do all cable gearchange boxes also use a hydraulic clutch?
golfvr6
Re:Gearbox Advice
« Reply #14 on: 20 July 2004, 10:24 »
The mk3 gti 8v has got a rod change not a cable change.
Thanks to Blacky for the picture of his engine bay  :D
http://www.golfgtiforum.co.uk/gallery/displayimage.php?album=random&cat=10848&pos=-760
« Last Edit: 20 July 2004, 10:49 by golfvr6 »
Offline Gambit
Re:Gearbox Advice
« Reply #15 on: 20 July 2004, 10:43 »
d'oh! my mistake ::)
still be worth getting under to have a gander at the code though just to be certain
for all you know, you could have a maestro box like me!! took me 2 years before somebody pointed it out to me!
golfvr6
Re:Gearbox Advice
« Reply #16 on: 20 July 2004, 10:47 »
Yeah Gambit is right, get under and have a look!  :D
Offline richandhazel
Re:Gearbox Advice
« Reply #17 on: 20 July 2004, 10:52 »
Gambit, thanks for that gearbox ratio link........very useful ;)
MK1_BOY popped round yesterday and we spent most of the day rebuilding a gearbox for him.......he went home last night with a nice new gearbox to fit to his rocket ;D
daros, get that code off your box.......that will reveal all ;)
Offline daros
Re:Gearbox Advice
« Reply #18 on: 20 July 2004, 19:29 »
Had a quick gander........from what I can see (without jacking the car up) the code goes something along the lines of CDH 120 114  ??? ??? ??? lol
That of any help?
David
Offline Gambit
Re:Gearbox Advice
« Reply #19 on: 21 July 2004, 12:04 »
CHD gearboxes where in 92-95 Golfs/jetta's
comparing the ratio's of an AUG box to the CHD, the CHD is slightly longer from 3rd onwards hence why you have to rev it further
