Author Topic: Starting query??  (Read 990 times)
Offline madhouse
Starting query??
« on: 14 September 2008, 22:43 »
The car is a 1997 1.4 SE we've recently purchased, however it seems to be a little tempremental with starting.
On turning the key sometimes it will power-up the fuel pump (i.e. it whirrs as normal) but when turning against the "spring" where normally the starter motor operates - nothing!
Other times starts first turn.
It seems if the key is pressed into the barrel it doesn't happen, but that could just be in my head!!  :undecided: Sooooo could it be a barrel issue or maybe a selonoid switch??
Common thing or any thoughts??
Oh and where is the starter selonoid switch on these?
Cheers Mark  :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Starting query??
« Reply #1 on: 14 September 2008, 23:05 »
you usualy get a click if the motor is sticky,   if there is no click it could be the ignition switch.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline madhouse
« Reply #2 on: 14 September 2008, 23:11 »
Bugger!  :grin: I thought this too, there's not a peep, kind of hoping of more a relay or selonoid type thingy. Be a pain if it's the barrel  :sad:
Offline Rmachines
« Reply #3 on: 15 September 2008, 00:24 »
the switch is easy to change, the barrel is a bit harder but still not to bad.    i would check the motor first.   mabey get another from the scrappy and see if that makes any diffrence?
Offline Rmachines
« Reply #4 on: 15 September 2008, 00:25 »
I have a good working starter here for a 1.4L AEX engine if you are interested  :smiley:
