Author Topic: rumbling noise?????  (Read 987 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
rumbling noise?????
« on: 14 September 2008, 22:39 »
Hi all my car has developed a rumbling noise near the alternator area.I think its the water pump but am a bit unsure. any ideas and is the pump easy to change on an agg engine
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: rumbling noise?????
« Reply #1 on: 14 September 2008, 23:04 »
Sounds like the water pump but look into the alternator first.
its a relativly simple job,  afternoons work, change the thermostat while your at it.  means removing the alternator brackets etc.. something i would put off untill the last minute because its fiddly but yea..  deffo a DIY job if you confident with a set of spanners.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline 01664gti
« Reply #2 on: 14 September 2008, 23:08 »
i need it for work at 2 tommorrow so gonna have to shift my ass.How is it best accessed and do i need to remove anything to make life easier
Offline Rmachines
« Reply #3 on: 15 September 2008, 00:23 »
jack it up and remove the driver side wheel remove the AUX belts etc...   you will need coolent as well,  they can be a pain to bleed so set a day aside for it.
Offline 01664gti
« Reply #4 on: 15 September 2008, 13:07 »
It was the water pump, the bearings had gone and also the fins on the back were worn funny. Bit of a pain but sounds great now
