Author Topic: Front Washers  (Read 852 times)
Offline kappatango
  • From Rice to V-DUB : No Going Back
Front Washers
« on: 12 September 2008, 19:02 »
HI,
My front screen Washer is not working - but the wipers dont move either when the stalk is pulled - I figure its the switch as the wipers work fine in standard positions.
This failed over about a week - was being picky about when it would squirt - but a wiggle of the stalk got a result - now nothing.
Whats to replace? A switch?? The Whole Stalk? And is it a pig of a job....?
Thanks
Kappa
Its not about how fast you drive - Its how you drive fast.......
Offline Conker
Re: Front Washers
« Reply #1 on: 12 September 2008, 20:08 »
Easy job so long as you've got a socket big enough to get the steering wheel nut off.  IIRC its 23mm (have a search to find out).
Get a new stalk off ebay, but be careful to buy the right version as the MFA thingy differs on some models. Alternatively whip it off and give it a good clean with WD40 and see if it clears up - Mine did and lasted for a few more months, then broke altogether.
Offline kappatango
Re: Front Washers
« Reply #2 on: 12 September 2008, 20:53 »
Awesome, thanks Conker - I will take a look on Ebay this weekend - is there an easy way to identify the one I need - is it an eyeball job, or go by the model??
E '88 Oaky Mk GTi
Offline monzablue16v
Re: Front Washers
« Reply #3 on: 13 September 2008, 12:38 »
24mm the steering wheel nut :)
Offline Conker
Re: Front Washers
« Reply #4 on: 13 September 2008, 16:24 »
Whats 1mm between friends?!?   :laugh:
