Author Topic: multitude of problems in my new GTI 16v  (Read 2063 times)
Offline TED
Re: multitude of problems in my new GTI 16v
« Reply #10 on: 12 September 2008, 15:53 »
Cheers for all your suggestions lads ill get trying them out pretty schnell!
Offline davero
« Reply #11 on: 12 September 2008, 20:25 »
Power steering belt change on a 16v is a bit awkward, i took out the plastic inner arch on the drivers side to do mine. Much more room to work from there.
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #12 on: 13 September 2008, 17:41 »
Had a misfire on my old 16v and changing the ecu and fuel pump relays sorted it, they are numbered 30 and 167 and are located in the fuse box above the fuses and are a common fault on mk3's. Cost about £22-25 from the stealers for both.
I'd also recommend changing the vaacum hoses as these tend to perish over time causing running issues, especially the throttle body to ecu one and the fpr to inlet manifold one. Get some 3mm id silicone stuff off ebay for a couple of quid.
As for the power steering, yeh thats deffo a belt issue, change the belt and all should be well.
