Author Topic: Where is the best place to order a sunroof seal on line?  (Read 1332 times)
Offline GTIDamo
Hi guys after some investigation it appears that my sunroof leak is due to several reasons:
1)Glass put back in incorrectly meaning drainage holes not working effectively and
2)Split in the sunroof seal at the front so water collecting in centre and dripping into car as there is no path for the water to get to the drainage tubes. So I need a new seal. Where is the best place to buy one online for a 1996 mk3 gti please?
cheers
Offline boneybradley
  • Back in a Mk3...
Re: Where is the best place to order a sunroof seal on line?
« Reply #1 on: 12 September 2008, 14:56 »
give eurocarparts or gsf a call....otherwise its back to mr vw stealer
« Reply #2 on: 12 September 2008, 15:36 »
That might be VW main dealer only.
kells
« Reply #3 on: 12 September 2008, 15:46 »
dealer, sure its around 30 quid, cant check/get part number till i get to my computer
Offline oliver07
  • golf gti T 200BHP
« Reply #4 on: 12 September 2008, 18:29 »
these are on ebay approx 40.00  :laugh:
Offline ToRo
  • Just because I won't - doesn't mean I can't.
« Reply #5 on: 12 September 2008, 18:40 »
Dealer charges 40+ - I know, I checked a week back!
eBay do them for around 30!
My leake was sorted by flushing out the drainage holes and pulling the seal tighter together! Failing that, put some silicon sealant on it mate!
  • Back in a Mk3...
« Reply #6 on: 12 September 2008, 18:50 »
have you thought about vaseline!!  :embarassed:
If rubber dries you can rescue it by using the said stuff.....it softens things up nicely!! making them (rubber etc) more strechy and I have used it to cure noisy door seals etc over the years and have had some good results
kells
« Reply #7 on: 12 September 2008, 20:26 »
boney is absolutly bang on here, you are supposed to frequently vasaline the seals, i do every couple of mopnth or so, i have done on all my cars, stops them from drying out
Offline Stu G
« Reply #8 on: 12 September 2008, 20:54 »
sunroof seal aint that much from stealers. might as well then ya know its right
