Golf mk3
hardmonkeys
were shud these wires connect 2
Topic: were shud these wires connect 2 (Read 2004 times)
greendragon
GTI forum regular
12 September 2008, 14:19 »
were shud this brown wire and a yellow wire connect 2 its on the same bit of loom the clips on 2 the throttle body
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Re: were shud these wires connect 2
12 September 2008, 16:17 »
Not sure but if you look to the middle left bottom of the picture it looks like there is a conector which has no plug? mabbey it went there?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Horney
10k hero
Racing, Trackdays, Starwars.
12 September 2008, 16:37 »
Is this a VR6?
nick
greendragon
GTI forum regular
12 September 2008, 16:56 »
yes it is 1993 vr6
davero
12 September 2008, 22:04 »
Will have a look at mine tomorrow and see if i can find out for you.
greendragon
GTI forum regular
12 September 2008, 23:51 »
thanks
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Reply #6 on:
13 September 2008, 00:27 »
If you dont get sorted..try this link for a pdf vr6 wiring diagram
http://volkswagen.msk.ru/electro/g3/g3_wd22_aaa.pdf
davero
Reply #7 on:
13 September 2008, 09:44 »
As Rmachines said there is a plug going to the empty connector on the picture. This is where those wires go on mine(1996 vr6)
greendragon
GTI forum regular
Reply #8 on:
13 September 2008, 12:55 »
so as its empty i can just tape um up
davero
Reply #9 on:
13 September 2008, 14:55 »
Mine has a plug attached to it, and the plug is connected to the grey sensor in your picture.
Golf mk3
hardmonkeys
