Author Topic: Brake Lines  (Read 748 times)
Offline rhysm5
Brake Lines
« on: 10 September 2008, 20:52 »
Need a bit of help on brake line sets. I have seen conflicting reports of which brake line set i need for my '96 8v GTI, discs all round. Is the the 4-line set or the 6-line set??
Also any one any experience on which set is best or easiest to fit?
Cheers for any help.
Rhys
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Brake Lines
« Reply #1 on: 10 September 2008, 21:18 »
Im not sure if it depends if its ABS or not but mine is four lines NON ABS.    but why dont you get your self a flaring kit and some unions then use copper pipe and do it your self... belive me its a hell of alot easier than fitting pre made steel pipes.   its bad enough without it already being made to shape  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline AudiA8Quattro
Re: Brake Lines
« Reply #2 on: 10 September 2008, 22:27 »
I thought all golfs with rear disc brakes have 6 flexible hoses, golfs with brake drums have 4.
Offline Rmachines
Re: Brake Lines
« Reply #3 on: 10 September 2008, 22:47 »
oh are we talking about Brake lines or flexi pipes here?   Kinda diffrent  :grin:
