Author Topic: sump question  (Read 2098 times)
Offline edpryce
sump question
« on: 10 September 2008, 18:28 »
Ok, so today i changed my oil for the first time on my golf.
When tightening the "plug"  back into the sump, it tightens up and then gets loose again. Unfortunately I cannot remember how tight it was when i loosened it taking it out to compare it with.
Is this normal or should it do up until it cant turn anymore? I am worried it might pop off when driving or just leak everywhere.
I am sure its not cross threaded as it turns cleanly but could the thread have died? I have moved the car and there is slight oil underneath the car but i think this is due to the general mess i made doing the job dripping down.
Any thoughts?
Thanks Ed
Offline Dolly
Re: sump question
« Reply #1 on: 10 September 2008, 18:34 »
sounds like the thread is damaged, probably stripped, it will leak. need a new plug and hope the sump Taps out, a new sump is £25 from GSF
Offline edpryce
Re: sump question
« Reply #2 on: 10 September 2008, 19:00 »
yeah its definately leeking now. Cheers.
Is it possible to re use the oil? or will it be dirty, its hasnt been run?
Ed
Offline Conker
Re: sump question
« Reply #3 on: 10 September 2008, 20:14 »
If you can catch it in a clean/decent tray, I would re-use it.
Remember to buy a new sump plug washer too!
Offline edpryce
Re: sump question
« Reply #4 on: 10 September 2008, 20:44 »
still got the washer. Will I need a new sump gasket too? I am thinking this is a simple case of just bolting the sump on and off?
Offline Dolly
Re: sump question
« Reply #5 on: 10 September 2008, 22:19 »
yeh aload of 10mm bolts round the outside. pretty straight forward. catch the oil in something clean and then pop it back in once the new sump is on.
Offline Conker
Re: sump question
« Reply #6 on: 10 September 2008, 23:00 »
A new washer is about 20p from ECP.  I fit a new one every time.
Offline edpryce
Re: sump question
« Reply #7 on: 11 September 2008, 02:44 »
fit a washer or gasket everytime? Or both?
thanks
Offline sidecarphil
Re: sump question
« Reply #8 on: 11 September 2008, 08:58 »
mine had no gasket (sealent) but if it has one yeah replace it and a new sump bung washer  :wink: :wink:
Offline bundy
Re: sump question
« Reply #9 on: 11 September 2008, 09:07 »
you might aswell do the gasket at the same time, saves you doing the same job twice  :wink:
