Author Topic: Bulbs!  (Read 1283 times)
Offline logeyboy
Bulbs!
« on: 10 September 2008, 13:28 »
Afternoon all,
I need some headlight bulbs for my MK2, but not sure of the  codes.
At the moment they only work on dipped, but one bulb  out on main beam.
Also when I put full beam on only one of these bulbs works  too.
I believe bulbs have codes H1, H5.. etc.
Does  anynoe know the codes for these 2 bulbs please and cheap places to buy them?
Thanks
Offline Jay
  • balding fat cvnt
Re: Bulbs!
« Reply #1 on: 10 September 2008, 14:23 »
Yu want H4's for your headlights and H3's for the inner spot lights.
Ebay do the cheap H4 Xenon bulbs but most people go for the Philips Vision Plus which are about £15-£20.
Offline 8v Grunt!
Re: Bulbs!
« Reply #2 on: 10 September 2008, 14:25 »
You will need H4 bulbs. Standard are 55w/60w.
You can pick them up very easily from alot of places, any motor factor, petrol station etc...
Should only be a few quid.
IMG]http://i303.photobucket.com/albums/nn131/wiggyfallaize/IMG_1781.jpg[/IMG]
Offline logeyboy
Re: Bulbs!
« Reply #3 on: 10 September 2008, 14:35 »
Offline Mook
Re: Bulbs!
« Reply #4 on: 10 September 2008, 15:59 »
I wouldn't buy a non branded set of bulbs - cheaper but they don't last.  As above, go for Philips, Hella or Ring, they'll last and the brightness is great.
MK5 & MK2 20V-T
Offline cняis
Re: Bulbs!
« Reply #5 on: 10 September 2008, 19:52 »
get branded ones for sure.
dont buy from halfords ($$$$$) and dont buy blue ones, as they give off LESS light than clear/yellow bulbs.  :smiley:
Offline daniel-1986
Re: Bulbs!
« Reply #6 on: 10 September 2008, 20:53 »
i got Lucas 30% brighter ones from carspares for about £8
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: Bulbs!
« Reply #7 on: 10 September 2008, 21:05 »
Offline ReDBull
Re: Bulbs!
« Reply #8 on: 10 September 2008, 21:31 »
I've got some Philips Vision Plus Bulbs from Awsome GTI and they are a hell of alot better than the standard bulbs.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Re: Bulbs!
« Reply #9 on: 11 September 2008, 11:45 »
check the fuses as well, theres a seperate one for each side
