Golf mk3
hardmonkeys
will 16v powerflow exhaust fit an 8v
Topic: will 16v powerflow exhaust fit an 8v (Read 1028 times)
cw3514
10 September 2008, 09:53 »
Hi
A mate of mine is selling his custom built SS powerflow exhaust, its off a 16v and was wondering if it would fit straight on to an 8 valve?
cw3514
Re: will 16v powerflow exhaust fit an 8v
10 September 2008, 10:04 »
oh 'tis cat back system as well
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
10 September 2008, 10:21 »
yes... Some of the later models had a bigger bore but even if it does it can bit fitted with an adapter. im pretty sure the cat flange is the same or might need minor adjustments.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
10 September 2008, 10:38 »
As all ready said... it will fit but may need an adaptor at the back of the cat...luckily the mk3 all ready uses a small extension pipe here so swapping that should sove any fitment issue
eightyeightmph
As mentioned, will fit fine but you might need a reducer to fit onto the cat.
2016 GOLF GTD
cw3514
10 September 2008, 11:03 »
OK
cheers for the replies guys, sounds like it will be worth getting and not too much hassle to fit
Golf mk3
hardmonkeys
