Author Topic: Powering up and powering down  (Read 2485 times)
Offline stealthwolf
« on: 09 September 2008, 23:15 »
Had a chat with a mate with ED30 DSG. He tends to be a bit ambiguous - you can never tell whether he's BSing you or if he's being serious. Makes it difficult to trust what he says.
Powering up:
On the way to work,there's a single track carriage way. Before this is the roundabout and in between the two are two lanes that eventually merge into one. I tend to overtake all of the traffic to bump ahead. Problem is that by the time I reach this point, the car hasn't really reached optimum temp (90*C) - more about 2/3 of the way there since that bit of road is quite close.
How do I quickly raise the temp? Matey says blip the throttle without load a few times (ie when stationary and in neutral). I've tried going in a lower gear than I would to normally use for maximum fuel consumption eg 3rd when I should be in 4th.
Powering down:
Apparently, after driving the car very hard, you should wait 30s or so before you turn the engine off. Supposedly this prevents the turbo from cacking up. Is this true? Should I do anything once the car has stopped (handbrake on, in neutral, all lights/stereo/heaters off)?
Offline Hurdy
Re: Powering up and powering down
« Reply #1 on: 09 September 2008, 23:43 »
I always give her a nice steady warm up before giving her a good prodding :grin:
Once the temperature reaches 90 degrees it doesn't mean that she is warmed up. I usually give her a few more minutes of foreplay before starting the real action :shocked:
Coming back down again - after reaching a crechendo, she will need to be brought back down gently. Do not simply abandon her, let her sit there gently purring away for a while before leaving her to sleep. :kiss:
Do you see the similarities? :wink:
Seat Leon Cupra Black 290 DSG
WhiteGTI
« Reply #2 on: 09 September 2008, 23:47 »
Correct. I believe that the gauge shows water temperature not oil temperature. Oil will take a few minutes longer to heat up to the required temperature.
If I've been driving hard, I tend to slow it down for the last 5 minutes of driving to calm things down under the bonnet, and then just wait about 30 seconds before switching off when I get to my destination.
Offline neg
« Reply #3 on: 10 September 2008, 01:04 »
Yep, oil temp follows shortly after water temp gets up to speed - checked it with VAGCOM once as I was interested so see myself.
Offline RedRobin
« Reply #4 on: 10 September 2008, 07:06 »
....Just adding the info that allowing the turbo a 'wind down' period before switching ignition off after a run, is no longer necessary as it was on earlier versions - So I understand.
Offline Top Cat
« Reply #5 on: 10 September 2008, 08:11 »
 :huh:  I just roll off and go to sleep.  :huh: oh forgot one thing always place sky remote close to chest just in case she hides it.  :kiss:
Offline Hurdy
« Reply #6 on: 10 September 2008, 12:35 »
She'll love you more my way :wink: :kiss:
Offline R32UK
« Reply #7 on: 10 September 2008, 13:28 »
Mines not long term.. so its wham bham thank you maam!!  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 10 September 2008, 13:46 »
VW advise NOT to warm the engine while the car is stationary, I try not to rev above 3000rpm until up to temperature. It's good practice in all turbo cars to let the engine run for a minute or two before switching off if you've been ragging it. With my old motor I use to slowly trundle the last couple of residential roads before pulling on to the drive, then leave the engine running while I switch off satnav/get receipts out of the glove box/check my makeup in the mirror etc. before turning off the ignition.
Peskarik
« Reply #9 on: 10 September 2008, 15:17 »
If you drive hard and turn off the engine without letting the turbo cool down, since the oil is not circulating anymore it may overcook and damage your bearings.
I always let it cool down, if driven hard, then a couple of minutes of idle, is driven gently, just 30 seconds, just to be on the safe side.
On the start I  do not move until RPM falls to 1000 or below, then once water is 90 I wait a few more minutes to get oil up to temp.
