Author Topic: rear abs sensor fitting??  (Read 1317 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 09 September 2008, 19:35 »
Hi all, I just recieved my diagnostics reader i bought off fleebay today.So i thought i would have a play around and plugged it in, everything is fine apart from right rear abs sensor.I knew i had a problem as the light was on thats why i bought the box of tricks,I have had a look at the sensor which is straight forward but the only thing i am unsure of is where the wire goes and where it connects to.
Offline dubburke
Re: rear abs sensor fitting??
« Reply #1 on: 09 September 2008, 19:42 »
I think you will find the wire connects under your rear bench
Offline 01664gti
« Reply #2 on: 09 September 2008, 21:11 »
ok ill have a look tommorrow, im going to ring round a few places to get a couple of prices.
How much do they usally cost????
Offline bored_Welsh_lad
« Reply #3 on: 10 September 2008, 10:03 »
gsf did me a front for 10 quid... i weighed up the odds of buying genuine n they wanted 45 quid... the way i look at it.. replaced 4x i still wont have lost any money
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline 01664gti
« Reply #4 on: 10 September 2008, 14:15 »
ok cheers ill give them a bell
Offline Baskey
