Author Topic: airbag light  (Read 999 times)
Offline faz186
airbag light
« on: 09 September 2008, 13:11 »
Hi guys,
the other day i was fitting my system in the car and i was messing aboutt witht he wires at the back of the dash, but now the airbag sensor light has come on and was ok before i did the audio system,
is ther some kinda of sensoer behind the tape compartment or under the glove box coz i had to take it off the get my hands in a small gap,
its a r reg vr6
faz
faz
Offline GOLF_MK
Re: airbag light
« Reply #1 on: 09 September 2008, 20:37 »
do you have a passenger side airbag?
Offline faz186
Re: airbag light
« Reply #2 on: 15 September 2008, 08:45 »
yes i have both
faz
Offline GOLF_MK
Re: airbag light
« Reply #3 on: 15 September 2008, 11:10 »
You have probably more than likely just disturbed the cable (this is a good example of making sure you disconnect the battery while working in the facinity of airbags so they don't log any faults!).
I suspect all you need to do is connect a vagcom and clear the codes to get the light out, someone on here close by with a vagcom might be able to help.
I have one in Ipswich if that's any help!!!  :grin:
Offline faz186
Re: airbag light
« Reply #4 on: 15 September 2008, 13:20 »
cheers pal,
but when peeps talk about vagcom is it a diagnostic machine
faz
Offline Mikester
  • Civic Type R
Re: airbag light
« Reply #5 on: 15 September 2008, 13:27 »
cheers pal,
its the same as, just a free program that you can have a laptop, and the correct lead can be picked up from ebay for a few quid. This way we can all help each other out, rather than being charged big bucks from a dealer or specialist with a machine.
Offline faz186
Re: airbag light
« Reply #6 on: 15 September 2008, 13:28 »
cheers for that pal, ive herd of this software and might invest in it wehn i get a laptop
thanks for the advice
faz
faz
