Author Topic: Help for a newbie - Mk3 Gti 2.0litre 16v  (Read 9657 times)
Offline Len
Re:Help for a newbie - Mk3 Gti 2.0litre 16v
« Reply #10 on: 17 May 2004, 12:24 »
Update - Well folks it wasnt the fuel pump relay - i changed that anyway coz when i tested it as advised it felt cool one side. But made no difference.
I also tested the ECU relay and that was cold so will change that as well, got it on order at local dealer.
So will come back to ya when i know more.
www.sas.org.uk
www.the-ace.org.uk
Offline brains
  • why didnt i buy a ford, like my dad told me????
« Reply #11 on: 17 May 2004, 13:06 »
im gutted for you, i had hoped that would work:(
i dont know if its an old wifes tale, but have a mate who had an old sirocco with similar problems, and he drilled a hole throught his fuel cap, it was some thing to do with preasure buid upin the fuel tank. you dont have to be that severe just take it off and go for a run.
hope this helps ;)
when i grow up i want to be a VR6
Offline Len
« Reply #12 on: 18 May 2004, 09:23 »
Thanks for that tip Brains.
If it aint the ECU relay (supposed to be in Today) then i will give your tip a try.
Does sound a bit old wife's tailey but on the other hand with modern injection systems there are return hoses and if one of those is blocked or restricted.......
www.sas.org.uk
www.the-ace.org.uk
Offline Whittle55
« Reply #13 on: 18 May 2004, 13:26 »
I had a similar problem on one of my other cars and in the end after all the hassle i found that the exhaust manifold was leaking air causing the misfire.
You could not tell until the engine was pulling between the revs were about 2500,3000,
Offline Len
« Reply #14 on: 18 May 2004, 15:32 »
Well thats another thing to try.
Just had a phone call to tell me the ECU relay is in so will find out if thats the cause in the morning and let you all know!
Mine disappears by 4000 rpm if you are still accelerating. But if you try to hold a high constant speed 90 mph on the motorway it happens again.
You get it as u lift off and again when u accelerate again. So could be a vacuum problem. Fuel or exhaust back pressure, either could be a cause.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #15 on: 19 May 2004, 10:18 »
 ;D ;D ;D
SUCCESS!!!  - BIG THANK YOU Guys
Got the ECU relay this morning and plugged it straight in.  BINGO! - I gotta driveable car again.
Cheers for all the suggestions
Thank God i found this Forum and joined it.
From a very happy man!
(Might have to change my monica now!)
www.sas.org.uk
www.the-ace.org.uk
Offline brains
« Reply #16 on: 20 May 2004, 08:04 »
superb ;)
Offline mk1
« Reply #17 on: 20 May 2004, 19:48 »
I am pleased the forum helped you to fix your problem, please show your appreciation and purchase some stickers off jv and pass the word ;).
Steve.
Offline Len
« Reply #18 on: 25 May 2004, 13:03 »
Will do Steve.
A 'T' shirt too - if it'll fit my XXL frame!
Just give me some time - gotta get Runtothesun outa the way first and recover - then i definitely will.
 ;D ;)
Thanks again to all.
Len
www.sas.org.uk
www.the-ace.org.uk
Offline Rich16v
Re: Help for a newbie - Mk3 Gti 2.0litre 16v
« Reply #19 on: 07 March 2005, 18:32 »
Just been looking through this old thread and found it was very close to my problem l've had for months now, l'd changed the leads,cap and rotor and vacuum hoses, then l found this and changed ECU and fuel pump relay woooooooooohooooooooooooo its running like a dream? :grin: :grin: :grin:
lf l hadn't found this site l would of spent loads trying to sort it and l've learned loads along the way.
cheers
Rich
« Last Edit: 09 March 2005, 01:41 by Rich16v »
