Golf mk2
vw corrado 9a no spark
Topic: vw corrado 9a no spark (Read 1179 times)
zain110
08 September 2008, 20:24 »
hi can anyone help me my corrado turned off whilst driving it now turns over but no spark changed d cap rotar arm its a 1993 20 16v 9a engine code
Mew
Re: vw corrado 9a no spark
08 September 2008, 20:36 »
COuld be hall sender or coil. Disconnect the king lead from the dizzy cap and place it near to the block head etc and when you turn the ignition on if there is one spark but then when you turn the engine over no sparks it suggests the hall sender. May be worth checking connections first though
Conker
08 September 2008, 20:39 »
My first check would be all the leads/connections going from battery to spark plug, making sure they aren't loose, corroded, or split.
Do 9a's have an ignition module? Could be that too.
Or ECU relay?
Good luck with it anyway!
Golf mk2
