Author Topic: Removing door cards on a mk3 GTi  (Read 1695 times)
Offline lee_lee08
  • 1996 GTI 8v
« on: 08 September 2008, 02:17 »
I need to try and have a go at fixing my door handle (exterior) drivers side!
Its becoming a pain to try and open lately, I have to use the total closure (key in the door turned to open position and held for 2 seconds) to make the windows open and then put my hand in and open the door!
I cant see any screws to undo to take the door card off, ive looked in the handle on the inside and can't see anything in there to unclip / unscrew! is there something im missing?
Offline G-Dub-8v
Re: Removing door cards on a mk3 GTi
« Reply #1 on: 08 September 2008, 04:47 »
Hi mate, the door card just pops off.
Firstly you have to remove the door handle cover in the inside ( Where your window button is)
That pops off and im sure its 2 screws from there.
G
Offline azzrobz
  • Mk3 GTi 16v Anni
« Reply #2 on: 08 September 2008, 11:31 »
Yep did this the other day tryin to fix my window, just remove the handle which will include the lecy mirror control switch, then theres 2 screws to undo, unscrew the door pin, then just remove going round the door, just be careful not to break any clips, then its a matter of unpluggin you door speaker, window switch, mirror switch ect, and then remove the sound proofing from the door, (which i totally destroyed!!  :cry:)
there we go job done  :smiley:
Offline troublestarter
« Reply #3 on: 08 September 2008, 15:22 »
if your are replacing the door handle on the outside you do not need to take off the door card as their is just 1 screw holding the handle on open the door look above the door catch there is a screw in the door in line with the handle unscrew that take out handle refitting is a reversal of removal
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
kells
« Reply #4 on: 08 September 2008, 16:39 »
as above
so easy my mates grannny could do it
Offline Benny T
« Reply #5 on: 08 September 2008, 22:29 »
as above
Does anyone else have really creeky and rattly door cards????? thinkin of filling mine with expanding foam to stop it, when i say filling i mean spraying a bit here and there to hold it and reduce movement, in the rears this is (less wiring)
kells
« Reply #6 on: 08 September 2008, 22:44 »
no mine are fine
could try new clips, maybe someone had them off in the past and its made it all a bit loose
the late models have a cusion type inner cover, that could be missing ??
