Author Topic: full beams become much brighter when switch is held back!  (Read 2016 times)
Offline Mr Blue
Re: full beams become much brighter when switch is held back!
« Reply #10 on: 07 September 2008, 13:12 »
mine does it too, when you turn your spots on the dipped cme on and give a dark patch directly infront of you. I want to know how i can change it so when spots come on the main beam stays on too.
Im sure an uprated loom will sort this for you. Did on mine
Offline dubsport
  • TDI POWAR!
« Reply #11 on: 07 September 2008, 13:34 »
All my dubs have done this, no idea why!
Nick
same here. :huh:
Offline cняis
« Reply #12 on: 07 September 2008, 14:30 »
this is normal, done it on my rover too.
H4 bulbs are twin filament (one filament for dipped, one for main) and just as you pull the stalk back both sets of filaments will illuminate.
Offline Khare
  • The bear that khares
« Reply #13 on: 07 September 2008, 14:48 »
that will just make it brighter, which they already are.
i think that's the problem.
Avoid H4 bulbs?
Offline cняis
« Reply #14 on: 07 September 2008, 14:51 »
Avoid H4 bulbs?
all mk2 headlights use H4 bulbs, you cant change them to single filament bulbs otherwise you'd need to somehow magically change the bulb mounts and introduce an additional bulb to the headlight!
Offline Khare
« Reply #15 on: 07 September 2008, 16:44 »
 :rolleyes: i knew that :smiley:
Offline Jay
  • balding fat cvnt
« Reply #16 on: 07 September 2008, 17:46 »
Avoid H4 bulbs?
Owned  :laugh:
