Author Topic: Short circuit  (Read 3146 times)
Offline ramjet
Short circuit
« on: 07 September 2008, 08:01 »
Hi Guys,
i did an error I guess.Took out the ecu and plugged it back as wanted to check the wipers.Now the car cant start and also fuel pump dont seem to run when ignition on.
Connected the pump directly and also did not start.Some guys told that the static could have short circuited the ecu.Oh god a stupid mistake.Anyway,Mines an AGU,anyone replaced the ecu number 6oa 906 018 AD.How much for a used ecu?? :cry:
Offline Rhyso
Re: Short circuit
« Reply #1 on: 07 September 2008, 10:47 »
did you not disconnect the battery before removing the ECU?
2nd hand one is about £50 or so
Offline bobbarley
  • I'm kind of a big deal...
Re: Short circuit
« Reply #2 on: 07 September 2008, 12:47 »
I love that film!!
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Short circuit
« Reply #3 on: 07 September 2008, 12:49 »
Hello m8,
I have had 100s of AGU ecus in and out of cars, with the battery still live and never had 1 problem.  It is very very hard to kill the Bosch ME3.8  ecu so I doubt you ecu is dead. The problem could be, that you pulled a wire out of one ofthe loom plugs, pushed in or bent a pins in the on the ecu. or knocked the ecu and caused a dry joint. Where are you from?
Nick
 01455 617233
Offline RTechUK
Re: Short circuit
« Reply #4 on: 07 September 2008, 12:51 »
I love that film!!
Brill Film.
My fav quote was  " Hey lazer lips your mother was a snow blower"
 01455 617233
Offline bobbarley
Re: Short circuit
« Reply #5 on: 07 September 2008, 12:51 »
Could you re-map Johnny 5?
Offline GTi-Matt
Re: Short circuit
« Reply #6 on: 07 September 2008, 15:34 »
I love that film!!
Brill Film.
i used to have that as a message tone!!! :laugh: :laugh: :laugh: :grin: :grin:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline ramjet
Re: Short circuit
« Reply #7 on: 07 September 2008, 16:14 »
Hi Nick,
Thanks for the reply.Ok I have a serious problem not really sure what to do.Also I checked with a scan tool and for engine dtc it says link error.
Also i'll tell you what i did,and i think it was my stupid mistake to do such but did try before and it didn't fail.Ok I attempted to change the chip as I was told by the previous owner ,he chipped the car but it doesnt feel as such.So I tried to fix the other chip and both chips are of the same make AMD and year 1997.After carefully putting it in I tried starting and it didn't.Changed over to the one that was in there in the first place and it to didn't work as well.
Ok I was in the UK before but am in Malaysia.The scan tool says Link error hence no comm between the scan tool and ecu or maybe the ecu is out.Also the meter cluster doesn't work now.What can i do.Thats the only think I touched but now am about to find out the real problem or yet to.
I hope you can assist.If mine is 60A 906 018 CG must i reset the immo and let me know if you can get me a used unit.Thanks bro.
Ram
Offline RTechUK
Re: Short circuit
« Reply #8 on: 07 September 2008, 19:18 »
Hello,
The immo is on the serial eeprom chip not the AM29f200 chip you are playing around with.
The Chip needs to be the same as the one that came out the number I think it should be is an AMD AM29f200BB ? Plus the information on that file needs to match the ecu and car.
The information on the file from your 06A906018CG 1.8L R4/5VT should be 0261200518 - 1037352127
If this is all ok then the problem culd be down to a naffed solder solder pad. chip fitted wrong way around, shorts on the chip legs, or solder shorting the some of the other chips.  You really have to butcher the ecu to kill it.
If you get another ECU you will need to change the immo chip or have the chip patched to work on your car.
The car could have already been remapped, but the power can lost via a boost leak, naff n75 or duff maf.
If you get another ECU you will need to change the immo chip or have the chip patchedto work on your car.
Nick
 01455 617233
Offline RTechUK
Re: Short circuit
« Reply #9 on: 07 September 2008, 19:20 »
I would to have a tinker with jonny5 on a tread mill to see how far I can push him until he goes bag.. :cool:
Nick
 01455 617233
