Author Topic: stock recirc/diverter valve, more power, remap and rambling  (Read 2691 times)
Offline itsbeen
Just bought a 2001 1.8T and have been reading on here for a couple of days about various problems etc.
One of the things that keeps cropping up is the stock recirc dumpvalve (or boost diverter as it seems to be called in VAG circles) not being good enough and leaking off boost.  Now, why do people need to replace them?  I kept reading about this and was aware of what they looked like (same as the old cossie ones) and I've had evos in the past where the boost bleeds off on WOT due to the valve not being able to hold anymore.  The cure was to reverse the stock valve on the evo and on boost it holds the valve shut instead of trying to blow it open.
I popped the cover off the golf last night and thought I'd reverse the stock valve just incase it wasn't holding boost and they are allready reversed as standard on these engines (which makes more sense to me) I've had cossies, evo's 944 turbo etc and they all have a similar design valve but the other way round so they leak off boost on WOT higher rpms.
So basically the stock VAG valve is already fitted so when the car is on boost it actually pushes shut rather than blowing open.
What all the above waffle is getting at is why do loads of threads on here mention changing them to stop boost problems?  It looks like the way they are fitted they'll hold ok on boost?
Or do they fail in some other way?  Not that I can see how as they are pretty basic and a good blow into it will see if it's sealing.
Reason I've been looking at these sort of threads is because the golf I bought developed a terrible flat feeling to it's performance, I know these engines like a MAF so bought a new Bosch MAF, cleaned the TB, bought some new Bosch Platinum spark plugs and got tinkering.
The car now idles and runs smooth as silk and doesn't have the flat feeling (like an anchor suddenly gets dropped lol) BUT the boost comes in hard at around 2krpm and you think ooh, this is fruity then it's like the power doesn't build and just feels a bit sluggish to how you think it's going to be.  I realise it's only 150bhp but the way the turbo comes in is like getting foreplay from the mrs and thinking here we go, then she gets up and fooks off!  The car seems to run ok now but the way these VAG engines deliver the power is very frustrating IMO  I had a cupra 20v T a few years ago and the golf has brought back the memories of the power delivery.
Been thinking of a remap but does it actually make the car feel fast over 3krpm?  I don't just want an amplified version of the stock MAP ie hit at 2krpm then a crawl to the redline.
My engine is the AUM engine and I've read it'll remap to 220bhp if it's got the k03-s turbo?  sods law it'll be the k03 turbo though so that'll mean 190bhp?
Is there anyway of easily finding out what turbo is on the car?  it doesn't look too easy to see any codes due to the position!  The car is a 2001 if that helps.
Offline T_J_G
Re: stock recirc/diverter valve, more power, remap and rambling
« Reply #1 on: 06 September 2008, 13:22 »
The code will be on the blue panel on the turbo hard to get at without removing.
I'd stop worrying about the stock valve and buy a Forge CL007p to make sure!  :smiley:
Offline itsbeen
« Reply #2 on: 06 September 2008, 13:28 »
That's the thing I'm not worried about the stock valve, what I was meaning was why do people replace them, what goes wrong?  I was under the impression they'd be leaking boost off but it's gotta be impossible the way round they are fitted to VAG engines.
Offline T_J_G
« Reply #3 on: 06 September 2008, 13:33 »
I'm unsure TBH, apparently the can go wrong after a remap so I scored a Forge item off ebay for £46 and it does seem to boost better.
Standard AUM aswell.
Offline itsbeen
« Reply #4 on: 06 September 2008, 13:36 »
Yeah that's why I presumed the stock valves don't hold boost well as most people say they are a must with a remap and the extra boost that comes with it.  I just can't see that being the case though.
Offline richw911
« Reply #5 on: 06 September 2008, 13:55 »
The standard valve are pron to crack and cant hold the boost from a remap.
Forge 007p FTW
All in here BTW:
http://www.golfgtiforum.co.uk/index.php?topic=87364.0
« Last Edit: 06 September 2008, 14:37 by richw911 »
Offline leeroy20vt
  • h reg mk2 gti
« Reply #6 on: 06 September 2008, 22:39 »
tbh i had a remap and a forge split r  1 day i thought im goin to play so put stock 1 back on and had a drive left it on there since seems to work much better than the forge and sounds nicer too i was hitting just under 16 psi with the forge and just under 17 psi with the stock work that out
since i took the forge off i have serviced and will put it back on 1 day wen it stops raining
Offline richw911
« Reply #7 on: 07 September 2008, 00:32 »
 forge split r is not a patch on forge 007p tho  :wink:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #8 on: 07 September 2008, 10:05 »
My thoughts exactly!!  ^^^
The OE DV is the right design, but sadly the diaphragm eventually splits - Even on std cars. This is then obviously accelerated on remapped cars. There's no set time to how long one will last, tho, as there are too many variables, but I went through 2 std DV's in under 12 mths (on a remap).
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
